Its came as a used machine without instructions manual so i conected it to the machine and i also change the:
COPIER > OPTION > INT-FACE>3
try to print test page the printer not response
imagePASS S1
The imageRUNNER 7105/7095/7086 is supported by imagePASS-S1 System Software Ver.1.0 and Ver.2.0
The imageRUNNER 7105/7095/7086/7095P machines support 1200 dpi image transfer, thus the imagePASS-S1 is connected using a Video cable and Ethernet crossover cable. Copier firmware requirements: When connecting the imagePASS-S1 with version 2.0+ to an imageRUNNER 7105/7095/7095P/7086, please make sure that the ROM levels of the copier or printer are at the level detailed in the following table. NOTE: If the imagePASS-S1 has version 1.0 earlier copier versions can be used but the imagePASS-S1 will not be compatible with the 7095P.
*NOTE:The imagePASS-S1 is supported for use with the C-type BootROM ONLY.
Before attaching the imagePASS-S1 to an imageRUNNER, in the service mode of the imageRUNNER, please make the following setting: Copier>Option>INT-FACE>IMG-CONT to “4”.
