Canon IR5000 error code e000225-0000
  • blu3sky
    • Jul 2010
    • 25
    [Error Code] Canon IR5000 error code e000225-0000
    i have canon ir5000 with the error code e000225-0000
    any solution???
    please help me
  • charm5496
    • 2387
    I would check your CCD unit, reader controller and the ribbon cable that goes inbetween the RCON and the CCD unit. Any of the three can cause the issue you are experiencing
    • teckat
      • 16083
      any solution???
      please help me
      what were u or did you or was customer doing before code ???
      • montana
        • Aug 2008
        • 393
        E225
        Main Cause The scanning lamp (xenon tube) is faulty. The inverter PCB is faulty. The
        CCD/AP PCB is faulty. The reader controller PCB is faulty.
        Mode of
        Detection
        0000 A specific signal level cannot be attained by CCD gain correction
        at power-on.
        0002 The edge gain correction value changed more than a specific level
        compared with the correction value used for the preceding sheet
        • 20YRSEXP
          • Oct 2008
          • 281
          e-225 is a scan lamp issue. Make sure the lamp is coming on first. If it is clean your optics and white plate and do a CCD adjust. If the lamp is not coming on get back and let us know. The xenon lamps rarely have trouble but it is not out of the question. Otherwise as Charm stated check the ribbon cable and connections. If those are all good start looking at the PCBs listed by Montana.
          Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
          • blu3sky
            • Jul 2010
            • 25
            provide oil on the rail
            • blu3sky
              • Jul 2010
              • 25
              i think e-225 caused from the glass not installed. Then I've installed the glass the code not be shown, but the copier cannot start just shown "wait"
              • teckat
                • 16083
                check the Fuser area
