Canon iR2200 system software
  • icb
    • Oct 2009
    • 28
    Hi everyone,
    I have problem with one iR2200 and need to replace the HDD and reload the sofware. Can anyone send me system software for iR2200 or tell me where to find it ?
    It would be appreciated very much.
    Thanks in advance.
  • JustManuals
    • Jan 2006
    • 9838
    Yet another one!
    • teckat
      • 16083
      Originally posted by icb
      Hi everyone,
      Thanks in advance.
      You need to pay good USA money for it/ nothing is Free
      • JustManuals
        • Jan 2006
        • 9838
        There you go!
        • charm5496
          • 2387
          the extra bucks are not worth the head ache and constant begging of more information. I would rather work for a living than sell my employers information....
          • teckat
            • 16083
            • Hejsan
              Uhu
              • Mar 2008
              • 42
              Hi everybody!
              Just checked the Service Menu (Copier > Display > Version) and this is what I found in versions section:
              DC-CON: 12.01
              R-CON: 07.01
              PANEL: 00.02
              POWER: 02.01
              FEEDER: 06.01
              SORTER: 01.05
              NIB: 03.00
              MN-CONT: 42.03
              BOOTROM: 26.44H
              RUI: 42.01
              LANG-EN: 43.01
              Seems that my iR3300 has the following BootROM - 26.44H.
              I have to versions of Firmware: iR3300_v45.01 and iR3300N_v45.01. I guess that none from above mentioned is compatible with my iR3300. Is it true? If yes, then I have to find the appropriate Firmware :-(
              Can I upload other Boot ROM to my copier, in order to have v26.44C or v26.44N at the end?
              Please, advise...
              Thanks to all in advance!
              • cableties
                • 35
                The version you have is the latest
                • Hejsan
                  Uhu
                  • Mar 2008
                  • 42
                  Thanks I just would like to know - is this Firmware (the version I have) compatible with my iR3300? It has the following Boot ROM: 26.44H
                  • cableties
                    • 35
                    YES IT IS
                    • Hejsan
                      Uhu
                      • Mar 2008
                      • 42
                      YES IT IS
                      Well Then why I can't upload it to the copier? It gives Error code 13 (Sub code 12) every time...
                      • teckat
                        • 16083
                        SST ERROR 13= Firmware Mismatch-selected Firmware is not the same as the Target Firmware /select and verify the correct Firmware
                        First-u need to uninstall/re-install SST- Then make sure your 3300 Firmware is not corrupted
                        also make sure u have only one version of SST on laptop
                        • teckat
                          • 16083
                          Hi everybody!
                          DC-CON: 12.01
                          R-CON: 07.01
                          PANEL: 00.02
                          POWER: 02.01
                          FEEDER: 06.01
                          SORTER: 01.05
                          NIB: 03.00
                          MN-CONT: 42.03
                          BOOTROM: 26.44H
                          RUI: 42.01
                          LANG-EN: 43.01
                          Please, advise...
                          to ADD ON
                          Your MN-CONT (System Software) & LANGUAGE Versions Must Match exactly
                          • Hejsan
                            Uhu
                            • Mar 2008
                            • 42
                            Thanks so much! First of all, how can I clean my PC from uninstalled SST? I wonder - is SST 4.22 suitable for uploading v43.01 System Firmware?
                            • mrfixit51
                              Lead Service Technician
                              • Oct 2008
                              • 1975
                              Easy:
                              Uninstall SST, then navigate to it's installed folder and delete it. I always load mine in the Program Files folder, but if it is installed in it's default location, it is C:\canon\servicesupporttool. Delete that folder. Deleting the C:\servtool folder will get rid of any previous versions of copier system software. Now you are ready to do a clean install of SST and the System Software of your choice afterwards...
                              4.22 is suitable for your needs...
