Hardware Tech Tips
imageRUNNER ADVANCE C7000 / C9000 Series
Tip: Upon installation of a new device, there is no need to initialize
the developing assemblies. If an initialization is executed, the
value of ATR is changed, thereby allowing possible light printing.
Initialization of developing assemblies is only needed at the
time of assembly replacement.
Tip: First, execute Shading Correction. If possible, use
the I1 spectrophotometer for this step.
Next , execute the Full Auto Adjust Gradation.
Finally,calibrate the RIP. If an EFI controller
is being used, use of the I1 spectrophotometer is best.
These adjustments will ensure optimal print quality.
