Hardware Tech Tips_
All imagePROGRAF iPF Series Printers
When replacing major components in the image-
PROGRAF printers >>
it is important to perform all the recommended
processes as shown in the Service Manual. For example
the Gap Calib and Optical Axis Adjustments are critical to a
successful repair after the Carriage Unit is replaced. In addition
the counter for the new assembly should be reset to maintain
the scheduled maintenance service counter.
When going into the service mode after replacing
either the Main PCB (CPU) or the Maintenance Cartridge Relay
Board (MC Board),imagePROGRAF iPF8000/9000 Series
Error codes 2F26 and 2F13 sometimes indicate a
Carriage movement error, prompting a Carriage Assembly
replacement. Instead of replacing the entire Carriage Assembly,
***** replace the two carriage bushings.
PROGRAF printers >>
