ir 5000 check hopper connection
  • srv
    • Aug 2008
    • 82
    Hi folks.I have a fault on a canon ir 5000 with "check hopper connection" showing on the display.There is no error code showing and I checked the toner hopper connector and that is connected.There are 2 plastic actuators that allow a new toner to be fitted are broken so that the toner hoppper cover cannot move across but I don't know if this has any bearing on the fault.I have limited experience on these m/cs so I would appreciate any input.Cheers
  • alysson
    • 25
    when u take out the toner unit, under it in right side there are one conector.. jsut plug it on and ur machine will back to work.
    • srv
      • Aug 2008
      • 82
      It is connected and I have checked the back of the conector it is connected to.
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        Online research showed that M5 motor in hopper can short out and also take out the DC Controller board... Start with the motor, and if that does not get it, go for the controller board. Make sure you don't try the board first, as the bad motor can fry the new board.
        Hell, replace both motors to be safe, or swap the hopper from a parts donor, then go to the board ...
