Canon lms error
Guest repliedGentlemen...I'd like to say thank you all very much for your contributions on this matter.
I got my IR3025 Printing now...i spoke to canon and they provided me with an activation key.
Thanks again.Leave a comment:
**Just called Canon, they said there is a typo error in Ref Guide-
u need the LMS FOR Both UFR II/PCL Printer Kit-S1 & PS Printer kit
u need to call Canon about the LMS issue u are having
The brochure info below is correct./ disregard Reference option list I posted.
sorry about that imagePass question, this model has no option for a Fiery.
Canon may have posted some misinformation on the UFR II/PCL Printer Kit-S1/, in the Reference guide it does not list that a LMS is needed, but in brochure link below it has the word "Activate the optional UFR II/PCL Printer Kit-S1"
here u go / pick out what u need>
Canon U.S.A. : Support & Drivers : imageRUNNER 3025
read the spec sheets /and brochures
[ATTACH]6108[/ATTACH]Leave a comment:
iR_3030_3025_bro_rev_070207.pdfLast edited by teckat; 09-08-2010, 04:56 PM.Leave a comment:
Guest repliedteckat, if i get you right, is imagepass somekind of a print server?
i am trying to print directly to the USB Port. is it possible to send me a link where i can get the right UFR drivers for the IR3025??
ThanksLeave a comment:
Hello Gentlemen, i downloaded and installed the UFRII PCL Drivers for IR3025 as suggested.
the Machine recieves the print job but nothing comes, i checked the prink log and the print status was indicationg...NG (#853)
wondering what i'm missing...is there a way to check if my model (IR3025) requires a certificate for LMS Activation??
Thank you for you continues help on this matter....really appreciated.
I POSTED ALL THE OPTIONS THAT NEED LMS ON YOUR SERIES MODEL IR MACHINE.
Do you have your imagePass hooked up to this iR3025 ??
#853
Are u sure you are using the UFR Print Driver to PrintLeave a comment:
Guest repliedHello Gentlemen, i downloaded and installed the UFRII PCL Drivers for IR3025 as suggested.
Thank you for you continues help on this matter....really appreciated.Leave a comment:
The S1 print kits are UFR/PCL and then there is also a PS kit as well. The 3045 does not come standard with this series like it does some others. If you are getting this error then the license key might be corrupt in which case you need to contact canon. Without seeing the key there is no way of telling.
If you scan it make sure you block out the key so no one takes and uses it on you....
The UFR II/PCL Printer Kit-S1/does not require LMS Activation
0n the iR3045/3035/3030/3025/ read the options for model that I posted, they show what options require LMSLeave a comment:
If you scan it make sure you block out the key so no one takes and uses it on you....Leave a comment:
Guest repliedThank you very much gentlemen....i am currently downloading the UFRII Drivers, will let you know how it goes.
SCREWTAPE>
That UFR II/PCL Printer Kit-S1 may have a certificate that is needed on other models that require LMS Actavation
I remember installing one these a while back. And yes, I don't remember having to activate any printing options. I believe it was standard.
Why don't attach a image of that certificate so that we can see.
As Teckat suggested. Set up the print driver.
There is no way your gonna get around this.Leave a comment:
