Canon IR3570 Fax Problem
  • Tim C
    • 167
    I need help with this issue on a Canon IR3570. The fax is not working at all. I installed the machine and set up all options, everything works fine. No error codes come up. What happens is as trying to send a fax, if I touch the Hook Key I get a dial tone. as soon as I touch the dial pad and start a number it just locks on that number as a continuous beep. It won't pick up a incoming fax either. I have replaced the Fax Controller and the Line in Board
    Then replaced the Power Supplies that the fax plugs in to and the one in front of that one.
    Same problem. The line is good.. they had a Canon IR400 using it as a fax and put it back there to use while I am trying to fix this one.
  • teckat
    • 16092
    your talking about Super G3
    install ?
    make sure line type in user mode & line type connected to machine match
    are your country & region settings/ set in service mode FAX>TYPE>TYPE
    did u go in Additional Functions > select System Settings
    select the option that reads " Restrict Access to Destinations
    enable the use of the fax driver_Allow Fax Driver TX >ON
    Press: TX Settings (under Fax Settings)
    Turn off the option, "Check for Dial Tone Before Sending"
    Shut down and restart the imagerunner
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Firmware could be corrupted.
      Trying doing a scan disk. Hold down 1&9 upon boot up, let it finish. It will say download mode.
      You can reboot or flash the machine at that point. I had a similar issue and performed the steps and it helped.
      • Tim C
        • 167
        Thanks for your help...It was the setting for Type..It was on standard I switched it to U.S.A. and it worked fine.
        I really appreciate the help guys!!
        • teckat
          • 16092
