E000748-4311 on iR-c2880
  • BillAgudelo
    • Feb 2010
    • 83
    Hi, Fellows,
    I have come accross this iR-c2880 that displays error E000748-4311.
    I appears that it used to have an imagePASS-J1 before, but it has disappeared.
    Is this error due to the fact that the iP-J1 is missing?
    What do I need to do in order to put it back to normal (no iP-J1)?
    Thanks,
    Bill
  • teckat
    • 16083
    Originally posted by BillAgudelo
    Hi, Fellows,
    Thanks,
    Bill
    go in service mode
    COPIER>OPTION>INT-FACE
    IMG-CONT set to 0 turn off & on printer
    An E748 4311 error can happen during transporting of the machine
    or if the controller box assembly is removed.
    imageRUNNER C4080 / C4580 / C5180 / C5180i / C4580i / C4080i / C2880 / C2880i / C3380 / C3380
    imagePRESS C1 / C7000VP
    E748 4311 Error Code on the LCD
    An E748 4311 error can happen during transporting of the machine or if the controller box assembly is removed.
    The sub controller RB-A PCB (Figure 935 FM2-6810-000) may not be installed or seated correctly.
    The PCB is held to the main controller by clip locks on the main board and a tension bracket that holds the board to the controller box assembly. Remove the bracket (with tension mount) and re-seat the Sub controller RB-A PCB (fig 935) to the main controller. Then reinstall the tension bracket.
    If not installed, please install the RB-A PCB. The RB-A PCB is included in the UFR II / PCL printer kits. Before installing the license, make sure to install this board or else you may see the E748-4311.
    • android790
      • Jul 2010
      • 63
      Also make sure the cable is there that plugs into the pcb. I had one shipped with it in a box that came with the machine.
      Yes, I am here to fix your machine. No, your machine went out of warranty 18 years ago.
