Printing (optional)*
You can upgrade this machine to a
high-speed network printer by installing the
optional Multi-PDL Printer Kit. This kit
incorporates UFR II (Ultra Fast Rendering
II) Technology, which utilizes a newly
invented printing algorithm to minimize file
processing and achieve maximum
performance. It also supports PS and PCL
at maximized speeds.
Sending Function (optional)*
The Send function enables you to send
scanned image or document data to file
servers, or send it by e-mail or I-fax. A
variety of file formats are supported (PDF,
TIFF, and PDF(OCR)), which offer you
greater flexibility in accommodating digital
workplace environments.
*The optional Universal Send Kit must be
activated by registering a license key.
Network Scanning (optional)*
The Network Scan function enables you to
use the imageRUNNER 4570/3570/2870/
2270 as a conventional scanner. You can
scan a document using the machine, and
read the data in an application you are
using on your computer, such as Adobe
Acrobat.
To use this function, the machine is
required to be connected to a network,
equipped with the Printer function, and
Network ScanGear to be installed on your
computer. You can scan images of up to
11" x 17" in size at a resolution of
600 x 600 dpi.
*The optional Multi-PDL Printer Kit must be
installed on your machine, and Network
ScanGear software must be installed on your
computer to use this function.
Network Interface
This machine can be connected to a
network using Ethernet (standard
equipment). Connecting to a network
enables you to use utility software,
including the Remote UI, NetSpot*,
NetSpot Console, etc.
NetSpot enables you to manage and make
various settings for the printers and copiers
connected to a network from a PC. NetSpot
Console enables you to perform the same
operations as NetSpot, but from a web
browser.
*NetSpot and NetSpot Console can be
downloaded from Canon's web site
(Canon U.S.A., Inc.), and they are
supplied with the optional Multi-PDL Printer Kit.
Faxing (optional)*
In addition to normal facsimile functions,
the machine offers you Super G3
compatibility, which enables you to transmit
documents at high speeds, greatly reducing
transmission costs as compared to
conventional facsimile machines. In a
mobile environment, you can also receive
faxes remotely from the machine outside of
the office.
If the optional Super G3 FAX Board or
Super G3 Multi-Line FAX Board, and Fax
Driver are installed, you can send
facsimiles from your computer. If you attach
the optional Super G3 Multi-Line FAX
Board, you can use two lines.
*The optional Super G3 FAX Board or Super G3
Multi-Line FAX Board is required.
