Canon IR5000 confused
  • RSCA
    • Jul 2008
    • 112
    The customer reported paper jams. The reason is that both trays 1 and 2 are displaying A4 paper size. Tray 3 is fine with legal and runs with no problem. Tray 4 displays A3. I have the re-boot procedure but is there something I am missing before I try that? I don't see any size detect sensors. There is no paper behind the trays. Thanks.
  • teckat
    • 16083
    execute auto size adjustments
    set guides at the STMTR position perform Copier > Function > CST > STMTR and then with cassette guides at A4R position perform Copier > Function > CST > A4R.
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      There are no movable guides in the LH or RH drawers, there is no auto size adjustment for the drawers. Need to go into Copier>Options>CST and make the change to 18... Then restart the copier for change to take effect.
      P-SZ-C1
      P-SZ-C2
      Use it to specify paper size used in the front deck (C1: right deck, C2: left
      deck).
      Caution After electing the appropriate paper size, be sure to turn off and then on the
      main power switch.
      Settings 6: A4 (default), 15: B5, 18: LTR
      • teckat
        • 16083
        Good Point for reminding me / I keep thinking about trays, instead of drawers- talk about Confucius/ u read enough of these posts in Forum- u start to become one
        • Canuck
          Tech Specialist
          • 1713
          You are partly correct.....this will fix his A3 in tray 4 problem
