IR3025 rebooting
  • ReproKev
    • 273
    IR3025 rebooting
    Machine will reboot every few minutes - sometimes when idle, sometimes during copying (which leaves a power-on jam after rebooted).
    This started happening after the machine was moved about 1/2 mile to their new location. Machine has no dents or obvious signs of shipping damage.
    I have reseated all connectors for main and dc con, single ram chip, bootrom and hard drive with no change.
    110K on meter, MN-Cont v23.01 DC-Con v3.04, has fax and usend in case it matters.
    Customer is billable so I didn't want to start ordering a lot of parts (don't have a parts machine on hand for this model).
    Any ideas?
  • teckat
    • 16083
    Any ideas?
    Go in Additional functions>System Settings>Network settings>TCP-IP>Multicast Discovery and setting it to "off" (default is "on").
    Power off the imageRUNNER for the changes to update on the machine. Power unit on.
    • ReproKev
      • 273
      Thanks for the reply.
      Is this a common issue?
      I'll talk the customer through it on the phone tomorrow morning and check back in the afternoon to see if it took care of the problem.
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Before the machine was moved, did it have this problem. I see you mention that it all started when it was moved.
        Your HDD could've gotton damage.
        • ReproKev
          • 273
          This is a new customer for me. They told me it all started after the move and I'm inclined to believe them.
          • SCREWTAPE
            East Coast Imaging
            • 3396
            I hear that.
            Check service mode for any errors in the history .
            • Canuck
              Tech Specialist
              • 1713
              Could be bad HDD from move.Clear the RAM and check the ground clip on the silver registration roller.And re-install the firmware......this is a cheap start
              • ReproKev
                • 273
                I had the customer turn multicast discovery off yesterday morning and she thinks the machine was fine for the rest of the day (machine is in a hallway by itself, but she can usually hear when it reboots). Time will tell.
                Thanks again.
                • CanonSco
                  Man About Town
                  • Jul 2010
                  • 368
                  Turning Multicast off might be a good shout , lets hope it is that.
                  BUT , I have had to replace 2 main controllers on these for randomly re booting.
                  Yes, I am a nerd.
                  Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
                  • teckat
                    • 16083
                    Thanks again.
                    thanks, hope it works out
                    • junkiemanxl
                      • Dec 2007
                      • 49
                      i did encounter the same problem as well. changed the HDD and did a reset and the symptom went away.
                      • teckat
                        • 16083
                        They had the customer turn multi-cast discovery off yesterday morning and she thinks the machine was fine for the rest of the day (machine is in a hallway by itself, but she can usually hear when it reboots). Time will tell.
                        poster fixed issue on suggestion above
