laserclass 710 how hard to
  • landspeeder
    • Feb 2010
    • 355
    change the laser scanner...scanner is the same as the lj 2200 and I have that part..just want an Idea before I go on site about changing it. thanks
    David
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
  • teckat
    • 16092
    David
    what was the issue it was having ?
    think it's 4 screws/and a flat ribbon cable
    HG5-2826-000
    LASER/SCANNER UNIT
    • costd
      • Jan 2008
      • 409
      Haven't had to replace one, but once you get the covers removed - it sits right there.
      • SCREWTAPE
        East Coast Imaging
        • 3396
        What is or was the problem.
        • landspeeder
          • Feb 2010
          • 355
          system E100 is the error and when it goes to print you do not hear the laser spinning up noise so we think its a failed scanner mtr. are we correct?
          • mrfixit51
            Lead Service Technician
            • Oct 2008
            • 1975
            I too get to do one today also,,, lots of covers and optical scanner assembly needs to be removed, than you have access to the laser...
            • landspeeder
              • Feb 2010
              • 355
              how long does it take and any hidden things etc to look out for?
              • mrfixit51
                • Oct 2008
                • 1975
                About an hour, in and out for me. I am not fax trained so I get my OTJ training that way. Ribbon cable to laser is the only thing I can caution you about, otherwise it is a lot of screwdriver time while you burrow down to the laser.
                • landspeeder
                  • Feb 2010
                  • 355
                  thanks I'll let you know how it goes!
                  • mrfixit51
                    • Oct 2008
                    • 1975
                    Success!!
                    Took me 50 minutes,,,, and 2 bandaids! That sheet metal in the controller cage is always biting me...
                    • landspeeder
                      • Feb 2010
                      • 355
                      I took about 60min and that is with my handy dandy electric screw driver. Metal cage is a bit sharp but no bandaids......when I plugged the machine in the scanner wound up and then it started to print...brought tears to my eyes and $$$$ to me pocket!
                      Thanks for the help!
                      • Canuck
                        Tech Specialist
                        • 1713
                        Is it intermittent or constant error? Reseat the connectors at the laser driver and also on the ECU and SCNT boards. Make sure that the cartridge has the plastic piece on it to open the laser shutter
                        • mrfixit51
                          • Oct 2008
                          • 1975
                          He already resolved the issue...
                          You're welcome!
                          Pulling the connectors off is what got me serrated. I brought in $531 for my efforts...
                          • Canuck
                            Tech Specialist
                            • 1713
                            His last post wasn't showing when i posted...time warp i guess. Yeah,thats why they call them CHARGE calls
