3200 image fault
  • alysson
    • 25
    3200 image fault
    hi, i have a trouble with my 3200. the copy is fault, as you can see in pictrure. I 've done the copy with feeder opened to see black image but its not.. its missing collors. i've change tranfer belt, is ok, transfer roller and keep the problem, even main DC power behind machine. (black). Nothing changed. some ideia?
    link of pic http://img230.imageshack.us/i/docz.jpg/
  • teckat
    • 16083
    post a PG10 test print/
    • teckat
      • 16083
      make sure your ITB is Camed up / + remove right side cover to expose ITB belt/ check image before transfer
      • "Harvey Dent"
        I'm with teckat. A PG type 10 will help.
