ir 3300 z bends at registration
  • lightningjeremy
    • Jul 2009
    • 139
    this machine intermitantly z bends the paper and jams at registration. the feed section has been replaced and so has the dc controller. has anyone seen this before? there doesnt appear to be any marks on the paper from hitting something out of place. please help. thanx
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Originally posted by lightning jeremy
    this machine intermittently z bends the paper and jams at registration. the feed section has been replaced and so has the dc controller. has anyone seen this before? there doesn't appear to be any marks on the paper from hitting something out of place. please help. thanks
    Have you checked the registration assy??
    • teckat
      • 16083
      Important> what are the jam codes+sub code or error codes+sub code
      • android790
        • Jul 2010
        • 63
        Wild guess because no codes. Vertical pass rollers. Worn,dirty, or needs the mod for that style of feed. It is a guide with leaf springs for pressure. There are other parts in the TP, but that main pt.
        Yes, I am here to fix your machine. No, your machine went out of warranty 18 years ago.
        • SCREWTAPE
          East Coast Imaging
          • 3396
          That's TPxx x27
          He said he replace the feed unit, which there is NPN for it.
          So, I assume he swapped it. He also said it z fold and jam at the registration area which is a little bit further up from the pick up assy.
          But good call.
          • lightningjeremy
            • Jul 2009
            • 139
            ended up being user error, thanx for all the responses.
            • teckat
              • 16083
              • mrfixit51
                Lead Service Technician
                • Oct 2008
                • 1975
                Share with the class,, how did the user create this problem? You may spare one of us the same grief later...
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  Ummm.
                  • teckat
                    • 16083
                    Originally posted by SCREWTAPE
                    Ummm.
                    hey maybe this customer knows the one I had who cut up brown paper bags to letter size/ feed in MF for an art project
                    / paid through the nose
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      D.F.U (Dumb F*%!ing Users)
                      • Canuck
                        Tech Specialist
                        • 1713
                        ID-10T jam codes
                        • zoraldinho
                          teacher-guide-expert-guru
                          • Mar 2008
                          • 5015
                          Originally posted by marc.lucas
                          I bet the customer just opened up a new good quality packet of paper & that fixed the fault!
                          I agree.50% issues solve with new packet.Can t believe.F.... paper.
                          • garvin
                            ir3300 Z BENDS
                            Hi,
                            Try a DC-CON clear,renter values on the door.Also check for the updated powersupply.
                            • teckat
                              • 16083
                              Originally posted by garvin
                              Hi,
                              Issue was a operator error issue/ read above/
                              ??? why would a DC-CON clr repair Z Fold ??
