Buffer Jamming - CLC 5100
SENSOR CODE
tahnks in advanceComment
MANY TINGS CAN CAUSE A DELAY TO DELIVERY/ also check the flag that paper hits on exit
That is a delay Jam = 0137 to Buffer pass delivery sensor PS3 (in Buffer Unit)
PS3= FH7-7250-000 SENSOR
FB5-8949-000
1 FLAG, DELIVERY SENSOR
make sure your buffer door magnet is holding door snug to keep switch closed/
your Orange buffer rollers could be slick & dirty
question ?? do u have a Sorter / or Finisher connected on CLC
J3.JPGLast edited by teckat; 09-21-2010, 05:17 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Re: Buffer Jamming - CLC 5100
FB5-8949-000
[ATTACH=CONFIG]6290[/ATTACH]
Thansk.Comment
u can not run the clc4000 with just the buffer pass connected
put back the Sorter
0137. This is a delay jam--2-0137-8
from manual feed>to Buffer pass delivery sensor PS3 (in Buffer Unit)>location Sorter
better check this also>>>>>>>>>
Due to a lack of lubrication and wear, the spring loaded drive coupling on the rear of the Fixing Unit becomes disconnected from the Fixing Roller Drive Collar. This allows the loss of the Fixing Roller drive and intermittent rotation . This happens so quickly that it is not noticed because it is only a momentary loss of drive. The result is an intermittent 0135 / 0137 jams.
Replace the Coupling (part number FB3-3768-000--remember to lubricate it.
check this also>>the rubber paper feed belts >they stretch ,underside becomes slick & slow down slightly causing the delay jam at the buffer pass.
tech tip>>> i used to remove both white pressure cams in buffer unit for those de-curling rollers**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
