chinese language in ir 3045
  • montana
    • Aug 2008
    • 392
    canon ir 3045 came with chinese language..how could i change it to english?
    please help!thank you
    • 16083
    it depends if all the Language Firmware was installed/
    Go to Service Mode, *, 2 and 8, *.
    Select Copier.
    Select Option.
    Select Body.
    Press the right arrow and scroll to the 3rd screen.
    Select RMT-LANG. For English, it should read en.
    To change the language, hit the +/- sign until you find the desired language.
    Select OK.
    Then power cycle the machine.
    or check below>>>>
    • Hit Additional Functions.
    • Select Common Settings.
    • Scroll down using the arrows.
    • Select Language Switch.
    • Select On and choose English. or What is available
    • SCREWTAPE
      East Coast Imaging
      • 3396
      If what teckat suggested works out for you, very well.
      If not, last resort would be to flash the machine with the eng-version.
      • montana
        • Aug 2008
        • 392
        thanks gentlemen..i'll give it try.
