Ir 6570 Imagepass M3 controller set-up
  • Brucere99
    • Oct 2009
    • 15
    The 6570 will not recognize the M3. Interface is set to 4. M3 was purchased used.
  • charm5496
    • 2387
    Have your cycled the power since changing you interface setting to 4?
    Are you using a crossover cable between the copier and the M3?
    Attached is the install procedure, but it is pretty straight forward. I can't remember if the M3 has to be at a certain version or not, but you might have to upgrade the RIP as well.
    • Brucere99
      • Oct 2009
      • 15
      The answer to both questions is yes. If the rip can't recognize the copier, than I can't determine what version is on the rip? Where can I get rip software? Thanks, Bruce
      • teckat
        • 16083
        If u need M3 software /u need to Call Canon Authorized Service Company
        *The optional imagePASS and Multi-PDL Printer
        Kit cannot be installed at the same time
        did u activate a LMS for anything on this printer before u decided to put a M3 on it ??(ex.Universal Send Kit-D1 *1) ???
        check for the LMS-based Printer Kit
        1. Press the [Counter Check] button on the copier control panel.
        2. Hit the [Device Configuration] button on the LCD screen.
        3. Scroll down through all of the available pages on this Device Configuration screen. Look for either PS, PCL or UFRII. The methods listed here (ex. PS, PCL, or UFRII) are installed and are available for printing.
        For example, if you find UFRII and PCL, but do not find PS on this screen on an iR C5180, it means that the UFRII/PCL Printer Kit is installed, but the PS Printer Kit is not installed. The exact Canon Printer Kits available vary by device model.
        Look in here to troubleshot>
        M3_I&SG.pdf
        What is shown on Control panel for Function Keys/use scroll bar below pic to see all
