Canon IR3300i Fax Line Detection - Cycles Itself
  • dbmoylan@gmail.com
    • May 2010
    • 89
    Might anyone be able to assist on a Canon IR3300i issue. The symptom is that when the fax line is picked up, and the IR3300i's display panel is off, the unit cycles (reader lamp goes on, side stacking unit cycles).
    This only occurred after some service mode settings had to be cleared and reset. Not sure if some of the settings were not reinput that affect this symptom. Unit is functioning fine but did not do this in the past.
    Tried several times to change the sleep and other web-browser controlled settings, but to no avail. I suspect it is a setting in the service mode that has to be modified.
    The cycling when unit turned off will occur whether the unit is off for 10 seconds (or less) or longer.
    Any suggestions are greatly appreciated. Thank you.
