IRC4580 Eror code Error e004-0101
  • harnrak
    • Aug 2009
    • 32
    I have problem with my IRC4580 when i turned on the main power switch the eror code appeared E004-0101. i tried to clear ERR already but nothing gonna happened. What is more i dont have Service manual. Thanks in advance.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    E004 Fixing unit protection circuit trouble
    0101 When there is a short-circuit detection error in the halogen heater (ASIC
    detection)
    Check the connection of the J114 jack of the AC driver PCB, and replace
    the AC driver PCB (triac short).
    Replace the Pressure heater.
    Replace the Fixing unit.
    Replace the DC controller PCB 2 (MAISY).
    How many copies have machine.
    • harnrak
      • Aug 2009
      • 32
      Thank zoraldinho very much for your good advice and i will try it
      • SCREWTAPE
        East Coast Imaging
        • 3396
        You might need a fixing assy. $$$$$$
        • teckat
          • 16083
          imageRUNNER C5180 / C5180i / C4080 / C4080i / C4580 / C4580i
          E004-0101
          Error :
          E004-0101: Halogen heater is damaged or terminal of heater has poor contact.
          Because of damage to the halogen heater (H1) or poor contact of a heater terminal, the error code "E004-0101" was indicated. This error code may be indicated due to a fault in the AC Driver PCB (i.e., triac short), the fixing assembly, and the DC Controller PCB 2 (MAISY). However, before replacing these parts, perform the following procedure.
          - E004-0101 can be displayed when there is a short-circuit detection error in the halogen heater (ASIC detection).
          1. Detach the terminal on both ends of the halogen heater, and then check to see if the heater has electrical continuity; if there is no electrical continuity, replace the heater with a new one.
          2. Check to see if the terminal [A] on both ends of the heater is fixed firmly with a screw. If the screw is loosened, tighten it.
          3. If the symptom still occurs, check to see if J114 connector of the AC Driver PCB is disconnected. If disconnected, re-fit it.
          FK2-2532-000 Halogen Heater (120V)
          FM3-0266-000 DC Controller PCB 2 (MAISY)
          FM2-6301-000 AC Driver PCB
