Ir5000 code E000020-0000
  • rasman67
    • Jun 2025
    I'm working on an IR5000 copier works for about 50 copies then goes to code. The copies are light in the center.
    Thanksin advance.
  • bojans
    • 1313
    E020
    The hopper connector is left disconnected. The hopper motor (M9/M10) is
    faulty. The toner sensor (TS1/TS2) is faulty. The DC controller PCB is
    faulty.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Check your developer as well.
      Copies are get light,
      check your bias connector thats on the developer.
      If there is a message on the screen of the control panel stating, Check hopper connector, then check it. If not, then check the developer.
      • D_L_P
        Self Employed
        • Oct 2009
        • 1196
        Another thing to check is the developer clutch. I've had to replace it once they get in the 2-3 million range.
        • cweber0531
          • 71
          I'm having the same issue with a 5570. What was your fix?
          • SCREWTAPE
            East Coast Imaging
            • 3396
            Your getting E20
            • cweber0531
              • 71
              Yeah and its starving developer.
              • SCREWTAPE
                East Coast Imaging
                • 3396
                IR5570
                Check if the flat spot on the 42 Tooth Gear in the Hooper Drive Assembly becomes rounded off.
                The part number for the Gear is FU6-0728-000.
                This could cause some feeding problem.
                • nick55
                  • Jun 2010
                  • 51
                  e020 my recollection tells me that ur hopper unit has toner and was not delivered to ur developer. temporary fix is to fill-up ur developer w/ toner to give u time to look for a hopper unit replacement.
