Ir4570 fax line a cannot work???
  • SESHU
    • 163
    #46
    Originally posted by mrfixit51
    The boxes look exactly the same, the only visual difference between the two setups is on the interface board that mounts to the main controller box, the one you had upside down. It is my belief that you have a single line unit in your possesion. It is doubtful if you had a dual line unit, that only one port would go out... Were you the one to install this feature, and was it new out of the box? Or did you inherit this problem?
    i can't understand..
    in mechine back fax modem two line pin jacks...line a and line b.
    on the board will goto 7 wire jack is connected.
    so its connected 7jack include line b line also or not????
      • 16083
      #47
        • 16083
        #48
        Look at pics above of inside of Faxes
        INSIDE A MULTI LINE FAX U HAVE TWO NCU PCB's
        because u see two lines outside/ it does not mean u have a dual line/ the same case is used for both boards/
        I told u how to check a while ago in service mode under version display - a G3 MULTI -LINE Always shows the version Firmware.
        it should look like this depending on ver. G3 Fax Board-D1 v79.01
        IN SERVICE MODE -under COPIER > DISPLAY > VERSION , if u see
        PSTN=On Board Fax.
        u have a single fax Q1
          • 16083
          #49
          It's simple/ the display will not lie / u don't even see a display setting to adjust two-line functions
          PSTN=On Board Fax.
          G3 Fax Board-D1 v79.01/ is shown for Mulit-Line
          there is nothing else to explain here
          • SESHU
            • 163
            #50
            PSTN=On Board Fax.
            u have a single fax
            thank you.. teckat.
            why i am going deeply for this topic whenever buy the mechine he told dula line board. and also checked and given the mechine...
            iam also checking those lines..
            so iam using single line still now also.
            now i want try to conect 2 line number for fax international use.
            its dail tone has not come.
            now warranty is out and also cannot ask about for this problem now.
            my doubt is inside dual line board one is not working well iam not using that now to.
            that 's iam asking..
            now i can check fax unit for result.
              • 16083
              #51
              if one of those NCU Boards did not function in a D-1/ you would receive a error code
              but the display would still show
              and two line adjustments would also show in fax settings-
              • SESHU
                • 163
                #52
                [QUOTE=teckat;169072]if one of those NCU Boards did not function in a D-1/ you would receive a error code
                MY HOPE IS GONE OUT...
                ANY WAY TECKAT I WILL TRY AGAIN.
                • mrfixit51
                  Lead Service Technician
                  • 1975
                  #53
                  Ask and ask and ask,,, pull the fax assembly out of the copier, crack open the case, and look inside to see if it has the extra parts that make it a dual line fax unit. End of story.
                  • MichaelConway
                    Canon Man
                    • Jun 2009
                    • 17
                    #54
                    Literally crack it???? ;D
                    Michael Conway
