canon ir-2016 showing download standby
  • tariq65
    • Jun 2010
    • 84
    i am facing this problem canon ir-2016 display showing download standby not work all keys.erroe red light glowing
    ani body help me thanks.
  • teckat
    • 16083
    did u just install a Printer Kit ??
    The Display will show "Download Mode" or "Download Standby" even though the imageRUNNER was not put into download mode. This may also occur after installing the updated Printer Kit-J1 [0446B005AA]. Turning the power on and off will not reset the message.
    flashing the machine to the latest system software may resolve the unusual message.
    Note: Printer Kit-J1 [0446B005AA] requires the new system software v60.02 be installed on the imageRUNNER.
    or re-flash the BOOT ROM with at least version 60.02.
    Installing System Software on the imageRUNNER 2020 / 2016 Series
    iR2016_2020.pdf
    The following modules must be installed from a PC connected to the copier via a USB cable using the Service Support Tool:
    - System (main controller) *
    - Boot (boot program)
    - PCL (PCL printer kit -J1)
    * The main controller also controls the reader.
    To flash the Finisher -U1 (Fin_U1), you must connect the PC to the finisher via a RS232C straight cable and the Downloader PCB (FY9-2034) using the Service Support Tool.
    Due to copyright restrictions, the 2020/2016 System Software is not available for electronic download. Please order this 2020/2016 system software as a service part using Part Number FY9-4240-003.
    To enter Download Mode on the imageRUNNER 2020 / 2016 Series:
    1. Hit Additional Functions, 2, 8, and Additional Functions to enter Service Mode.
    2. Press the + or - key to scroll through the Service Mode options.
    3. Scroll to '#DOWNLOAD'.
    4. Hit the OK key.
    • android790
      • Jul 2010
      • 63
      I had this happen to me for no real reason. The flash fixed it. You should follow what teckat posted. Save yourself time and money.
      Yes, I am here to fix your machine. No, your machine went out of warranty 18 years ago.
      • tariq65
        • Jun 2010
        • 84
        thak so mutch sir.
        • mahmoud
          • May 2012
          • 8
          Re: canon ir-2016 showing download standby
          [ATTACH]6356[/ATTACH]
          4. Hit the OK key.
          Iis it necessary to flash the finsher, i mean will it work if didnt flash it. by only downloading:
          -System (main controller)
          • teckat
            • 16083
            no/ not unless u have an issue with it/ or the firmware is old
            READ THIS PDF>>important info on Firmware-iR2016 Firmware_TP11_141.pdf
            • mahmoud
              • May 2012
              • 8
              READ THIS PDF>>important info on Firmware-[ATTACH]16088[/ATTACH]
              • teckat
                • 16083
                try to enter service mode> even though download message is present--
                Use it to clear all settings/registration data except the counter (denominator, numerator)
                To perform an 'ALL CLEAR', enter service mode by pressing additional functions > 2 then 8 and additional functions again. Scroll to #Clear and press ok. Next,select ALL and press ok. The imageRUNNER may power cycle itself.
                Note*
                After performing the ALL CLEAR, the imageRUNNER will be set to factory default and user inputted values will be lost.
                Firmware ver= don't u have a Spec Report ??
                To print a Spec Report from the imageRUNNER 2016 / 2016i / 2020 / 2020i:
                1. Enter Service Mode by hitting Additional Functions > 2 > 8 > Additional Functions.
                2. The Service Mode screen appears displaying [#SSSW].
                3. Hit the Left Arrow 6 times. [REPORT] is displayed. Press OK.
                4. Press the Right Arrow 1 time. [REPORT OUTPUT] is displayed. Press OK.
                5. Hit the Right Arrow 5 times. [SPEC LIST] is displayed. Press OK.
                6. The Spec Report is printed out.
                u may be able to check in RUI
                • eccsd
                  Note*
                  Hi teckat,
                  I've just stumbled upon your posts here, but am wondering if it would be possible to flash my iR2016 using a Mac. (I haven't installed anything new at all, but don't have access to a Windows PC.)
                  Many thanks in advance for any and all advice!
                  • spectraindo
                    • May 2008
                    • 313
                    Unfortunately the Canon SST work only on a Windows PC, there is no Mac version.
                    • eccsd
                      yikes! thanks just the same.
                      • teckat
                        • 16083
                        There is no OSX version for SST.
                        read somewhere about loading XP on Mac w/Boot Camp installed & using SST
                        what about using "Parallels Desktop for Mac" program ?
                        • eccsd
                          Ah yes Boot Camp, though just now after I turned the iR2016 off (unplugged it) and back on, it's behaving itself again... I'm keeping my fingers & toes crossed until further notice.
                          Thanks again!
                          • arisekolade
                            Re: canon ir-2016 showing download Im Akinyemi Olayemi Nigeia male. Pls I need your b
                            Im Akinyemi Olayemi Nigeia male. Pls I need your brotherly assistant on how to get service support software fo be able to reset my canon 2016ir back from download standby mode thank
