instal hdd ir5000
  • aldescopier
    • Aug 2025
    instal hdd ir5000
    how instal harddisk ir5000..?
    if use SST, how get SST..?
  • teckat
    • 16083
    you need SST for new HDD/ + u need machine Firmware
    Best Bet is>
    Put in a Service Call for experience Tech
    • aldescopier
      Can you give me SST n its firmware?
      Please, I really need?
      send to aldes_gwbgt@yahoo.co.id
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        Without experience you can have more issues with SST.
        • garvin
          You will also need the new usb to parallel cable from Canon.
          • bnmand
            • Sep 2008
            • 383
            You don't necessarily need a USB to parallel cable. If you have an old laptop with a parallel port or a desktop PC with a parallel port you can use that and a standard IEEE1284 bi-centronics parallel cable.
            Yes, Canon makes the only usb-to-parallel cable that works with SST.
            • aldescopier
              I do not have a SST,.
              other way than to use SST..?
              please.,.
              i need link SST DownLoad..
              if anyone have it. please send to aldes_gwbgt@yahoo.co.id
              • Gunawan
                • Sep 2010
                • 8
                are you a tech ?
                not only SST, you also need firm ware, like teckat say.
                • mrfixit51
                  Lead Service Technician
                  • Oct 2008
                  • 1975
                  Putting the cart before the horse here,, you also need the correct hard drive here as well.
                  1. correct hard drive
                  2. Service Support Tool
                  3. iR5000 System Software
                  4. Someone who knows how to properly accomplish this task...
                  It might be time to call in a Canon trained technician...
                  Be brave enough to state where you are actually living, don't put nonsense answers in your profile. Be proud of who you are and where you live. People will be more forthcoming with you!
                  • Gunawan
                    • Sep 2010
                    • 8
                    aldes, check your email.
                    • aldescopier
                      thanks bro gunawan,,
                      for your info,,,
                      • aldescopier
                        for your info,,,
                        please check your email,,
                        • badboys
                          • Oct 2010
                          • 69
                          Clone "IT". Save all the trouble.
                          • HU_Canon
                            • Oct 2010
                            • 18
                            Hi.
                            No need USB to PARALEL Cable. If you have a clone image from the original HDD.
                            We do not have to use Canon's USB cable from LPT1 Parallel
                            Archived images you copy from HDD to a virgin HDD.
                            Then just turn on the MFP and use it.
                            • teckat
                              • 16083
                              Originally posted by HU_Canon
                              Hi.
                              u better make sure the cloned HDD has no impending issues / & permission from a customer to do so./
