Canon 3025 send problems
  • SUSANVV
    • Jun 2025
    We have a Canon 3025 on a workgroup. The Send used to work to go to each computer after selecting it on the copier. Now when we send we get "No Response". There is no firewall up. It is connected to a Westell router modem and each computer can print to it. The folder on each computer that it should send to is shared. I am out of ideas. TIA for any help.
    sue
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    sue
    Shared folder must be allrights
    • zoraldinho
      • Mar 2008
      • 5007
      Do you see folder with send browser?
        • 16083
        sue
        when u hit SEND TAB, that message "No Response" show on screen ?
        or it just does not function when pressed ?
        how are the other Tabs functioning
        U can try a MMI CLR
        but before u do print out a User Data list for network and comm settings , CHECK & write down your IMG-CONT SETTING/and do an MMI>clear in service mode./ turn off/on Printer check settings from user data/ re input if needed
        Afterward
        • asky
          is DNS RUNNING have changed workgroup name or has your spam filter filter been turned
          sue
          i
          • SCREWTAPE
            East Coast Imaging
            • 3396
            sue
            Was anything change within the network properties? (User name , password)
            Are you able to see your workgroup when you browse out from the machine.
            What kind of computers are you running?
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Check the Shared folder (Sharing and Security tabs) and make sure it is configured properly.
              Make sure the User Limit is set to Maximum Allowed or at the least more than 1 user.
