IR 3300 Drum Roller Replacement/Service Manual Questions
  • NxlKing2304
    • Jul 2025
    [Misc] IR 3300 Drum Roller Replacement/Service Manual Questions
    I'm looknig for a service manual for an imagerunner 3300? See Below:
    I have a ir3300 which is printing black lines on copies. Obviously the Drum is shot. I'm changing the Drum Roller, and would also like to know what else I should be changing at the same time? What rollers should I clean to ensure that machine runs smoothly. I know i should contact a service professional, but i'm a DIY kinda person, and can handle the task. Any help would be appreciated!
    Andrew
    PS: Could use a copy of SST for this model if somebody is willing to share!?! Don't want to overstep my boundaries by asking...Sorry if I did.
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    We don't rebuild, simply buy a new drum assembly and your problems are over...
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Buy a new drum. Don't waste your time rebuilding, it will not last long and you will end up spending more.
      • teckat
        • 16083
        Andrew
        best bet/ put in a service call/ eliminate any headaches
        • badboys
          • Oct 2010
          • 69
          Katun drum cyclinder will the best replacement if you're cutting down $$$....with of course a new cleaning blade as well......5x cheaper then the original drum unit. Are a tech? If not then DON'T........
          • NxlKing2304
            not a tech, but i replaced both the drum and blade, and it is working amazingly!!! I also lubricated the urethane blade with dusting powder.
            • bojans
              • 1313
              I use k***n drums. It's not big deal to replace it. All work fine. I replaced one iR 3300 today, it worked 110 000 copies...
              • badboys
                • Oct 2010
                • 69
                Replace it at every 40-50k for best result....cheers.
                • bojans
                  • 1313
                  Why???
                  If it works 100k, why change it before. This machine has reached 3million and it's developer assy is in very bad condition, so i believe it could make even more if it was new.
                  • CanonSco
                    Man About Town
                    • Jul 2010
                    • 368
                    Think I may have an old GP215 cylinder in the garage somewhere I can send you for the cost of a 24 pack of beer , a squirrel , 1x lederhosen ( XL ) and a pack of Malboro's.
                    Just change the whole drum and be done with. What do they cost now?....$100 or something?
                    Yes, I am a nerd.
                    Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
                    • teckat
                      • 16083
                      Easy ! Just Print your own money/when u are a little short
                      • badboys
                        • Oct 2010
                        • 69
                        Originally posted by teckat
                        [ATTACH=CONFIG]6476[/ATTACH]
                        ...hehehe...In my country you can go to jail for doing that...GOTCHA...
                        • badboys
                          • Oct 2010
                          • 69
                          Originally posted by bojans
                          Why???
                          ...like i said "for best result".At 100k, print/copy tend to fade. I don't wait till my customer call to complaint when I've notice the issue a day before or so....time is precious & time is also $$$. Afterall the cost is low. 5x lower then the original drum.
                          • badboys
                            • Oct 2010
                            • 69
                            Why???
                            IR3300 developer assy lifespan = 480k>500k
                            Should be replace if you intend to use it longer.
                            IR3300 machine lifespan = 5 millions
                            Get it overhaul if you intend to use it longer.
                            • blazebusiness
                              SanDiegoCopierRepair.com
                              • 1250
                              When you install the new drum don't forget to do the adjustment in service mode or it won't go it's full life expectancy and will fail early. Very important with this model.
                              • Start Service mode. * / 2&8 / *.
                              • Go to "COPIER>FUNCTION>DPC>D-GAMMA".
                              • Press the OK key. The machine will pick-up paper from cassette 2. Paper size does not matter. The machine ends APVC correction by delivering a blank sheet.
                              • Press the reset key twice to end service mode.
                              Failure to follow the above steps will decrease the drum life.
