Wondering if anyone has seen the following issue?
IRAdvance 5030 with internal finisher-
Gripper mod done and running version 45.xx software.
Finisher output tray more often than not driving to the bottom and staying there.
4x Black curved arms that come out on top of paper sometimes coming out more than once / trying more than once to deploy/ seem weak... Eventually causes 010c Jams.
Sometimes works no probs , but more often than not the tray will be in the wrong position. As if it thinks tray is full of paper , but gives no errors / msg and lets you copy as much as you want.
Have stripped it down and nothing physical to see wrong with either the tray or the black arms.
Have had a number of issues with other internal finishers , broken harness - controllers etc , but first I have seen this on a 5030. Any ideas?
Also keen to hear of peoples experience with FF90 / 1101 /010c etc jams from the 3-way unit. ( which this machine is also suffering from - thats for next visit )
We have had some success with cutting all the stupidly tight cable ties coming from the sensors. But I have had to replace 3 x 3-way units to totally eradicate FF90 jams now. Which is worrying if they have not changed the manufacturing process and I am putting in the same as what is coming out. But the new units seem to work.
Any suggestions
Any suggestions
