Canon IR5065 Error code
  • Zoollanderhu
    • Aug 2010
    • 76
    Hi Guys!
    Unfortunatelly we've met with an error code at a Ir5065. We don't have a clue where shoudl we start to find the problem. Anyway the Errorcode is: E000001-0010.
    Thank you for your helps
    Norbert
  • Fer
    • Nov 2009
    • 267
    Never heard of IR5065, maybe u mean 5075 instead, fast b/w machine. E001 means overheat of fixing thermistor, most probably the roller is jammed bij folded piece of paper. Other problem could be a worn lower roller bearing preventing the fixing from turning around.
    • sweet.persona
      Engineer
      • Nov 2009
      • 414
      hello
      If after resetting the error and you still get the error code than the fixing film for the IR-5065 will have to be replaced and the error will have to again be reset. The part that is supposed to be getting hot is bad and only that part will need to be replaced.
      For the IR-5070, the error code is that the heater is not getting hot. If the error has a 0000 sub code then the thermistors may need to be replaced or the DC Controller. Most likely the heater itself is not bad because thay should last the life of the copier. Try doing an error reset by going into service mode. Additioan function key, 2&8 at the same time and then Additional function key. Slect copier, then function, clear, err. If it goes back into the error the above items may need to be replaced. Good Luck. 0010 sub code is that the copier has been turned off and on without restting the error.
      A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
      DAMENE ABDEL AZIZ
      DJELFA
      • Canuck
        Tech Specialist
        • 1713
        5055,5065,5075....same machine pretty well. There is not a fixing film in this model. It uses induction to heat the upper fuser roll. Replace the thermistor assembly with the newer style if it doesnt already have it. You have to find out what error happened before the E001-010...probably E001-001
        • Zoollanderhu
          • Aug 2010
          • 76
          We'll try it.
          • Zoollanderhu
            • Aug 2010
            • 76
            Thanks you.
            • teckat
              • 16083
              imageRUNNER ADVANCE
              The Canon iR 5065/N black and white multifunctional high productivity office printer, offering management controls, enhanced security and is network ready.
              • teckat
                • 16083
                Originally posted by Zoollanderhu
                We'll try it.
                Try this first> after re-set> ERROR CLR
                E001-0000/0001/0003
                Copier > Option > CUSTOM > TMP-TBL set to -2
                Copier > Option > Image Fixing
                FN-ENTMP set to -2 (if problem persists set to -4)
                FX-S-TMP set to -2 (ITOP Adjust for plain paper 1)
                For Heavy 1, 2, 3, or Thin paper:
                Copier > Option > Image Fixing > TMP-TBLxx (Adjust the paper type that is having the issue.)
                FX-S-TMPxx -2 (Adjust ITOP for proper paper type)
                Turn copier OFF / ON
                OR
                disassembling / re-assembling the fuser unit and re-installing it into the machine. After re-assembly the temperature never rose above 216 degrees Celsius. OK !!!!!!!!!!
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  IR5065.
                  • Zoollanderhu
                    • Aug 2010
                    • 76
                    E001-0000/0001/0003
                    OR
                    Wooow
                    Really Really appreciate your comment.
                    We'll try your tipps.
                    Thank you
                    Norbert
                    • Fer
                      • Nov 2009
                      • 267
                      We don't have those in the Netherlands, just 5055 and 5075. I still think the most probable cause is a jammed roller by paper or worn lower bearing.
                      Any comments on the new Lower rollers with the bearings allready pressed on?
                      • SCREWTAPE
                        East Coast Imaging
                        • 3396
                        So far so good over here in the states.
                        That's strange that you don't have the 5065. Its expected to happen however, marketing I guess.
                        • Fer
                          • Nov 2009
                          • 267
                          Had 3 5055/5075 die on me within a short period. Kept returning with E001 after a few day's. I replaced the Thermistors, machines where fine after. 500k on the counter
                          Strange enough, those same thermistors lasted for 1,5-2m on the 5570.
