Canon IRC 3200 warming up
  • xcopytech
    • Aug 2006
    • 1792
    Have constant message warming up.
    There is no any fault code on screen.
  • Van Steal
    • 177
    Check DENS in service mode, which ever one is 3/4% away from 0 replace toner bottle for that colour. If that doesn't work replace that drum.
    • pinheiro
      • May 2009
      • 51
      Hi
      Check in service mode Dens the value for each individual colour. The normal value would be between 0 and 1. If you have a colour with a value around 4 or 5 you have an issue with the toner/starter concentration level for that colour. By replacing that Drum Unit you will temporarily resolve the issue due to the Developer Assembly being incorporated with the Drum Unit, To resolve this issue replace the Toner Cartridge Drive Assembly - FG6-8999-000 and the corresponding Drum Unit. Before replace those parts, check if the Toner Cartridge is supplying or not the toner due to the broken inside stirrer.
      • badboys
        • Oct 2010
        • 69
        Had this similar problem once where the yellow toner clogged & choke. Replace it & everything OK......good luck.
        • pga
          • Jul 2009
          • 67
          tried change yellow or black drum unit. do the fixing unit working condition?
          • blazebusiness
            SanDiegoCopierRepair.com
            • 1250
            If you are still having trouble then check the toner cartridge drive assy or toner cartridge broken stirrer or toner is clogged as per pinheiro's advice in his post
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Bad drums can cause this as well.
              Bad memory DIMMs on the Main Controller can caused this as well.
              Does the fuser unit get hot?
              • xcopytech
                • Aug 2006
                • 1792
                Thanks everyone for answers. Fuser unit get hot and will check all rest posts and post here solution.
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  At least that's not the issue. Process of elimination.
                  • xcopytech
                    • Aug 2006
                    • 1792
                    Customer forced print with emptu toner and destroyed yellow drum unit.
                    Thanks everyone for help
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      Umm.
                      Glad you figured out.
                      • badboys
                        • Oct 2010
                        • 69
                        "Customer forced print with empty toner"...???
                        They must be damp desperate i should say.....
