IRA 9060 pro
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    IRA 9060 pro
    HI too all.
    Every time when machine do calibration procedure (every 50 prints maybe) i got
    different color image.Is someone have some skills with this issue.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Originally posted by zoraldinho
    HI too all.
    Thanks in advance.[ATTACH=CONFIG]6487[/ATTACH]
    Have you done a manual auto gradation.
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1257
      Try this......................Auto Correct Color Mismatch, select Settings and Registration > Adjustments >Maintenance > Adjust Image Quality > Auto Correct Color Mismatch
      • pga
        • Jul 2009
        • 67
        for my understading, the color consistency is not improve from iPRC m/c and iRC model. When print huge number jobs,we can see the color different from 1st page to last page.
        • Fer
          • Nov 2009
          • 267
          Probably office customers are tired of endlessly long adjusting gradation IRC2620
          • SCREWTAPE
            East Coast Imaging
            • 3396
            Canon emphasizes that the first print should look like the last print.
            That's why there is a,
            Image stabilization control.
            D-max control
            D-half control
            ARCDAT control
            PASCAL control
            Color displacement correction control
            ATVC control
            O, I can't forget ACR (Auto Carrier Refresh) control.
            • MrB
              • Nov 2009
              • 147
              Do you have you I1 gratag installed, and do you have a fiery with command work station
              if yes to them
              do S.A.C.s calibration
              Shading
              Autograd
              Calibration
              This should help
              • SCREWTAPE
                East Coast Imaging
                • 3396
                if yes to them
                Shading
                Autograd
                Calibration
                This should help
                Over here in the states we call it auto gradation.
                I guess you call it S.A.C..
                But,
                What is this??? I1 gratag installed.
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  Normally, "Gretag" anything is a spectrophotometer.
                  They make tons of different models.
                  • SCREWTAPE
                    East Coast Imaging
                    • 3396
                    Okay. I see now. Thanks Ken.
                    • zoraldinho
                      • Mar 2008
                      • 5015
                      if yes to them
                      Shading
                      Autograd
                      Calibration
                      This should help
                      I try this many times but nothing.I solve problem in service mode turn off autograd.
                      • KenB
                        Geek Extraordinaire
                        • Dec 2007
                        • 3944
                        You're quite welcome, Screwtape.
                        BTW...EFI labels that one the "ES-1000".
                        • blazebusiness
                          • 1257
                          That's not a fix.......you just disabled the feature and avoided diagnosing the problem. Auto gradiation is an important feature. I would continue dianosis and try to figure out why the copier is performing the calibration every 50 copies or so rather than shut it off. Perseverance my friend!
                          • SCREWTAPE
                            East Coast Imaging
                            • 3396
                            Yea I've seen that one while I was in training.
                            • Fer
                              • Nov 2009
                              • 267
                              U can calibrate the imagepass to the machine with a densitometer. But that doesn;t prevent the machine to vary its colors during a run.
