Using smb scan, was working, printing code 806 on error report, i dont have a manual, going to this call shortly, anyone have a manual or can give me some insight?
Canon is-1025if scan to file code 806
The SMTP is not properly configured.
1-Check and verify that the correct SMTP server name is
configured in Additional Functions.
2-Check and verify that you are using a valid DNS server
that has the correct name resolution to that SMTP server.
3-Check and verify that the correct SMTP server IP address
