ImagePRESS C-1 - Error code E00070 - 001
  • COCODIAZ
    • May 2010
    • 31
    [Error Code] ImagePRESS C-1 - Error code E00070 - 001
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    E070 code---Check home pos sensor
    There is an error of the detection of the ITB home position.
    xx=01: ITB home position sensor
    Turn off the main power, check the drive of ITB, and then, turn on the main power.
    Is the primary transfer pressure lever engaged?
    • pga
      • Jul 2009
      • 67
      it might be the home position sticker on ITB belt dirty or home position sensor.
      • COCODIAZ
        • May 2010
        • 31
        How can check the home position of the sensor ?
        • blazebusiness
          • 1250
          Well for starters you need to visually inspect the sensor to see if it is dirty. From your question---I suspect you haven't worked on many of these. Buy the service manual and familiarize yourself with disassembly and location of sensors.
          • COCODIAZ
            • May 2010
            • 31
            Dont have you a diagram with the location of ITB sensor ?
            • blazebusiness
              • 1250
              If you are not familiar with this model it's going to be tough for you to service it. The home pos sensor is only one possible cause for this code. I have seen a torn ITB belt and other stuff cause this. Not an easy machine to work on if your not trained. You may want to reconsider handling this service call. You may do more harm than good taking it apart to diagnose it.
              • SCREWTAPE
                East Coast Imaging
                • 3396
                PS1
                ITOP-A sensor
                ITB home position detection A
                FK2-0161
                P002-10
                0 : HP
                E070
                PS2
                ITOP-B sensor
                ITB home position detection B
                FK2-0161
                P002-09
                0 : HP
                E070
                On me.
                • teckat
                  • 16083
                  Cal for Help, before u tackle this Model- Don't be Brave
                  • SCREWTAPE
                    East Coast Imaging
                    • 3396
                    I agree with Teckat on this one.
                    Don't be a dare devil..
