Image press c1 jam 010d
  • Van Steal
    • 177
    Has anybody EVER had any luck fixing this jam code A4 only.?? Done all the mods (ps15/16 springs) sep drive gear, oiled fixing belt(and replaced it!!) Replaced sensors related to code. Replaced pre fixing belt ass'y. Checked fixing pcb. This jam code starts to come in to m/c after about 30k. M/C upgraded to latest version. Have it on about 5 C1's. Help anyone
  • seeb
    • Nov 2009
    • 41
    I have a C1 that had intermittent 010D jams on LTR paper. Replacing the upper fuser roller and lower fixing belt fixed it.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Check the Mount Separation Drive Assembly: FM2-7983-000, this drives the lower fixing belt assembly.
      Before removing the mount assembly be sure to scribe the two mounting brackets.
      • Van Steal
        • 177
        Thanks Guys, have try both tips with no joy but will keep trying
        • teckat
          • 16083
          Had success playing around with Level 2 settings below
          after replacing all that other crap
          can't exactly remember some settings/
          in Level 2> COPIER>ADJUST>FEED-ADJ
          REG-SPD Make a fine adjustment of the registration motor speed at constant speed.
          Change the registration speed at constant speed in the range of + or - 10 scales
          against the default value.
          Setting range 2
          -10 to 10
          Standard value
          0
          REG-SPD2 Make a fine adjustment of the registration motor speed at 1/3 speed.
          Change the registration speed at 1/3 speed in the range of + or - 10 scales against
          the default value.
          Setting range 2
          -10 to 10
          Standard value
          0
          **just to add on /if u have a Counter installed/ or Equitrc - set in
          OPTION/ACC >CC-SPSW to 1 also in Level 2
          U probably already know that !!
          • Phatnezz
            • Sep 2017
            • 2
            Re: Image press c1 jam 010d
            Setting range 2
            -10 to 10
            Standard value
            0
            the default value.
            Setting range 2
            -10 to 10
            Standard value
            0
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 5015
              I hope you realize that the post is from 2010 and probably nobody has C1 anymore.
