e255 (black lines on ir5000)
  • andalasgt
    • Oct 2010
    • 49
    [Error Code] e255 (black lines on ir5000)
    At first error e225. The technician replaced the CCD. After changing the CCD, it's become normal. But after 2 weeks the results like this ...(see Attachmennt)
    Thank's for advices
    • 16083
    never heard or seen E 255 CODE ???
    Looks like a bad LAMP/ see if is blinking
    E225=
    Check your ribbon cable./ did tech do a (CCD>ADJ)
    Check the scanning lamp
    Check the inverter PCB is
    Check if the CCD/AP PCB is faulty.
    Call the back Tech or request an experienced person~~~~~~~~~~
    • andalasgt
      • Oct 2010
      • 49
      I am sorry, you're right e225.
      yes I will call the back Tech.
      Thank's any way
      • victor_v
        • 71
        Failure in laser
        Failure in work of the low-voltage power supply
        Can be will help..
        Hardworking people are not present. Simply many it is boring to idle.
        • SCREWTAPE
          East Coast Imaging
          • 3396
          E225-0001 Error code: Due to faulty Lamp Inverter PCB Ass'y
          Symptom
          E225-0001: due to faulty Lamp Inverter PCB Ass'y
          Description
          Low reproducibility with a single scan. This error is more likely to occur during the second sheet scanning or later when multiple sheets of original are set on the DADF. In such a machine, even performing the following service mode is no effective: [COPIER>FUNCTION>CCD>CCD-ADJ].
          Cause
          In the past, a malfunction of the Toshiba-made switching regulator IC on the Lamp Inverter PCB occurred due to variations of its circuit components. This caused unstable illumination of the lamp, resulting in E225.
          Field Remedy
          Replace the Lamp Inverter PCB Ass'y with a countermeasure one.
          FH3-7211: EXCEPT INCH/A SIZE
          FH3-7212: INCH/A SIZE
          An diode has been added in order to accommodate variations of the circuit components.
          E225 Error code details Standard white plate/edge white plate read error
          0001 A specific level cannot be attained for the signal during CCD gain correction at power-on.
          0002 The edge gain correction level is different from the correction level for the preceding sheet by a specific level or more.
          Main cause
           The scanning lamp is faulty. The CCD PCB is faulty. The rear controller PCB is faulty.
          Action
          1. Scanning lamp (LAMP1)
           Is the lamp ON during the initial operation after the main power switch is turned on?
           NO: Replace the scanning lamp.
          2. CCD unit, Reader controller PCB
           Try replacing the CCD unit. Is the problem corrected?
           YES: End.
           NO: Replace the reader controller PCB.
          Also when the CCD is replaced there is a procedure that has to be taken afterwards.
          • andalasgt
            • Oct 2010
            • 49
            Thank You
            after CCD tried in another machine by the technician, the result is the same as the picture I sent.
            what is a procedure when the CCD is replaced?
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Originally posted by andalasgt
              Thank You
              Points to Note when Replacing the CCD Unit
              1) Check to make sure that the Execute/Memory lamp in the control panel is OFF, and turn off the main power switch.
              2) Disconnect the power plug from the power outlet.
              The machine remains supplied with power as long as its power plug is connected to a power outlet even when its main power switch is turned off. Be sure to disconnect the power plug.
              1. COPIER>FUNCTION>CCD>CCD-ADJ
              2. COPIER>FUNCTION>CCD>EGGN-POS
              3) Replace the CCD unit.
              4) After assembling the machine, connect the power plug to the power outlet, and turn on the main power switch.
              5) Execute the following service modes in sequence:
              6) See that all items of COPIER>ADJUST>CCD is updated. Record the results on the service label.
              7) Turn off and then on the main power switch.
              8) Make test copies in book mode and feeder mode, and check to make sure that they are free of displaced images. Otherwise, execute the following:
              Book Mode
              A: COPIER>ADJUST>ADJ-XY>ADJ-X
              B: COPIER>ADJUST>ADJ-XY>ADJ-Y
              Feeder Mode
              C: COPIER>ADJUST>ADJ-Y-DF
              9) Execute the following in service mode to generate a service label; FUNCTION>MISCP> LBL-PRNT. Store the service label in the service book case.
