says copy limit reached clear job/print log? whats this mean?
ir 2550
I know that copies can be limited in service mode also. You could try to enter service mode and check the setting for "Copier > Option > User>CopyLIM."Last edited by blazebusiness; 10-21-2010, 03:20 PM.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
"Reached counter limit.
above message is displayed when the page limit of the specific User ID is reached. The setting for the specific User ID can be changed under: Additional Functions > System Settings > Dept. ID Management > Select the arrow keys to display the department whose age limit you want to change > Select the department > Press edit > Select 'Turn Limits On/Off and Set page limits' and press the desired function.* To cancel setting a page limit restriction for a function, press [Off] under function's name.
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Taking into consideration that this only happens to you on color prints-don't bother checking the Copy Lim in service mode as I previously suggested.....Follow Teckat's suggestion. He nailed it.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
User said he does not have dept ID's set up. This knowledge base article refers to dept ID's.Comment
u never know/stranger things have appeared with further investigations
usually ,copy limit does not show up unless programed in/
i suppose it could be a software glitch ?
I agree with you, that message doesn't come up for any other function besides Copy limits. As we know where that gets set up at, Dept ID..
I guess we will wait and see what else molson has to say.
Chances are he won't post for another two years.Comment
