canon ir7105
  • ivc
    • Oct 2010
    • 13
    #16
    It is new
    • ivc
      • Oct 2010
      • 13
      #17
      olso prints
      VLT AND VLM IS AROUND 30
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1250
        #18
        Originally posted by ivc
        It is new
        What's new...that clutch? Have you tried turning off Pot Control? What did the copies look like after that? If they are still black focus your efforts on a problem with the laser.
        • ivc
          • Oct 2010
          • 13
          #19
          Originally posted by screwtape
          its a weird case but won't hurt to check.
          Tray 1 vertical feed clutch cl8 had metal shavings around it, causing electrical feedback to the machine.
          Cleaning up the area and replacing cl8 resolved the black copies.
          screwtape you are genius. It is weird, but the problem was clutch.
          I just can belevied. It just like the car wont start, and you replaced the tire and car workS
          normaly.
          Thank you
          ivc
          • ivc
            • Oct 2010
            • 13
            #20
            it is new
            no, the primary corona is new
            • teckat
              • 16083
              #21
              normaly.
              Thank you
              ivc
              I read that tech pub just now/ amazing / to believe a case study (rare)
              • ivc
                • Oct 2010
                • 13
                #22
                FINISHER
                Configuration:
                System Software Ver.41.01
                IR705
                Saddle Finisher V2
                Punch unit U1
                SL2 decide witch trayA/B will be selected
                When upper tray is selected, selenoid SL2 does not hold wright path( He pulls,but not hold)
                he replace SL2, but stil not working.
                JAM Code: 110B, 100A or 1109
                ivc
                • blazebusiness
                  • 1250
                  #23
                  normaly.
                  Thank you
                  ivc
                  Glad to hear your problem is resolved! Kudos to Screwtape for the good advice.
                  • teckat
                    • 16083
                    #24
                    Configuration:
                    IR705
                    Saddle Finisher V2
                    Punch unit U1
                    ivc
                    that firmware is old/
                    new is v80.02.02
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      #25
                      normaly.
                      Thank you
                      ivc
                      Truly I can't take the credit. But glad your up.
                      • techjunkie
                        #26
                        I've seen this many times. A test would be if it does it from trays 1, 3 and 4 and not tray 2. Tray 2 bypasses this clutch. A sure test!
                        • nick55
                          • Jun 2010
                          • 51
                          #27
                          can u download that tech pub screwtape? the one that pertain to cl8...its so interesting
                          • teckat
                            • 16083
                            #28
                            Here u Go >
                            October 26, 2007 Product : imageRUNNER 7086 / 7095 / 7095 Printer / 7105 Title : Intermittent black copies with the image on it. Problem :
                            Intermittent black/negative image with a halo effect on the text.
                            Solution :
                            Tray 1 Vertical feed clutch CL8 had metal shavings around it, causing electrical feedback to the machine.
                            Cleaning up the area and replacing CL8 resolved the black copies.
                            • teckat
                              • 16083
                              #29
                              More CL8 INFO>
                              imageRUNNER 7105 / 7095 / 7095 / 7086
                              imageRUNNER produces a 0101 jam code when making copies from deck one.
                              The jam code 0101 is produced due to CL8 not turning the feed roller. This code is occurs because the tab that secures the clutch is broken. To resolve this issue the feed assembly must be replaced. The part number for the feed assembly is FG9-3889-010
                              Product : imageRUNNER 7086 / 7095 / 7105 Title : An 0214 Jam is Occurring, When Using the Right Paper Deck, Cassette 3 or Cassette 4
                              Problem :
                              The jam 0214 occurs when feeding paper using the right paper deck, cassette 3 or cassette 4. Paper fed from the manual feed tray or the left paper deck runs properly without jamming.
                              Solution :
                              The main motor drives all of the vertical path rollers. The vertical path 1 rollers, which rotate when the CL8 clutch energizes, are used when paper travels from the right paper deck, cassette 3 or cassette 4. Paper traveling from the manual feed tray, left paper deck and duplex unit do not use these rollers.
                              The CL8 clutch was checked in service mode COPIER>FUNCTION>PART CHECK>CL number 7 and tested OK. In this case, the Right Deck Feed sensor, PS27 was replaced to resolve the issue.
                              • ivc
                                • Oct 2010
                                • 13
                                #30
                                new is v80.02.02
                                how can i upload finisher with firmware.
