problems .....
+ More Options
Posts
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Misc] problems .....
    hello l have copier olivetti copia 9021 ..it's same canon 6621 ..so if l started copy ..l have black copy ..please can you healpe me ...other can you sent me the service manuals of this copiers machine ...if you have in french longage please .DSCI0002.JPG
    BEST TECHNICIAN . NICE PEOPLE .
  • teckat
    • 16083
    Originally posted by zaza
    hello l have copier olivetti copia 9021 ..it's same canon 6621 ..so if l started copy ..l have black copy ..please can you healpe me ...other can you sent me the service manuals of this copiers machine ...if you have in french longage please .[ATTACH=CONFIG]6808[/ATTACH]
    CHECK YOUR SCAN LAMP/and or HARNESS FOR BREAKS or CRACKS
    • teckat
      • 16083
      Turning ON/OFF the Primary Charging
      Roller Bias
      Under the control of the microprocessor master
      (Q301) on the DC controller PCB, the micro-processor
      on the composite power supply PCB generates
      the PCTRLS signal (pulse signal), which causes
      the secondary side of the transformer (T4) to go ON
      and the primary charging roller bias to be applied.
      3. Controlling the Primary Charging
      Roller Bias to a Constant Voltage
      The microprocessor on the composite power
      supply PCB reads the PDCS signal (analog signal)
      from the voltage detection circuit while the bias
      voltage is being applied to the primary charging
      roller and controls the PDCPWM signal so that the
      output voltage remains constant.
      4. Switching the Application Voltage
      Level for the Primary Charging Roller
      Bias
      The machine applies a cleaning bias to the
      transfer roller during initial rotation (INTR), when
      the scanner is moving in reverse (SCRV), during
      last rotation, and at power-on after a jam. (See p. 3-
      46.)
      To improve the efficiency of cleaning by the
      cleaning bias and to prevent residual memory on
      the drum by the cleaning bias, the primary charging
      roller bias is applied during initial rotation and while
      the scanner is moving in reverse.
      5. Automatic Correction of the Application
      Voltage Level of the Primary
      Charging Roller Bias and the Scanning
      Lamp ON Voltage Level (APVC,
      ALVC control)
      Changes in latent static images can affect the
      copy quality; such changes in latent static images
      result from
      • changes in the drum sensitivity, and
      • changes in the charges from the primary
      charging roller.
      On the other hand, these changes occur because
      of the site of installation (temperature, humidity),
      deterioration of related parts, wear, or dirt.
      The machine’s light area potential (VL) and dark
      area potential (VD) tend to increase. To correct such
      an increase, the machine corrects the application
      voltage level of the primary charging roller (APVC
      control) and, at the same time, corrects the scanning
      lamp ON voltage level (ALVC control), thereby
      ensuring a specific degree of light area potential
      (VL) and light area potential (VD) at all times.
      Cleaning the Cleaning Pad and the
      Caution:
      • Dry-wipe only. Do not use water, alcohol,
      solvent, or any alcohol- or solvent-related
      agents.
      • When dry-wiping, use strokes in one direction
      only.
      clean the primary charging roller =with
      lint-free paper = while rotating the roller.
      Points to Note When Handling the Photosensitive
      Drum
      The copier’s photosensitive drum is highly susceptible
      to light; mere exposure to room light can
      affect the drum enough to produce white spots or
      black lines on the copies. Keep the following in
      mind:
      • Do not spend more than 5 min when removing
      jams.
      • After detaching the drum unit from the copier
      during servicing work, be sure to protect it in
      the light-blocking sheet that came with the
      drum or fresh copy paper, and place the drum
      in a dark place.
      Do not touch the photosensitive drum or primary
      charging roller
      If you have soiled the surface of the drum
      inadvertently, wipe it using a flannel cloth coated
      with toner; do not use paper, lint-free or otherwise.
      Do not dry wipe or use solvent to clean the drum.
      • zaza
        MECANOGRAPHE
        • Mar 2008
        • 1095
        thx lot tech nick
        • nick55
          • Jun 2010
          • 51
          suggestion: make a sky shot and check how the scanning lights up. if it goes off in the middle of scanning then u have crack on ur cable as previously mentioned before by our fellow tech teckat. Too bad, i got some of this in stock b4 but i threw it away including the unit....it's too old
