Canon IR 2020 Error E007
  • pj_ghazi
    Hi
    I have problem with my canon Ir 2020 after 3 or 4 copy it shows Error E007 .. and some times when i turn on the copier it shows this error .
    How can I Fix this error ... please help me .
    Thank You in Advance.
  • kwazimoto
    • Jan 2007
    • 199
    E-007
    the book say fixing film sensor failure.. more then likely it is the fixing film itself ..it is something to do with the rotation of the film if it is rotating at all
    • willy brown
      Originally posted by pj_ghazi
      Hi
      THE PROBLEM IS WITH THE FIXING FILM, IT HAS A SENSOR ON ONE SIDE THAT IS WERE THE FILM IS TORN. REPLACE THE FIXING FILM
      • sobujos
        Re: Canon IR 2020 Error E007
        Before changing any thing. just try this. Check if your paper size is exactly same as it says.
        Because in my case, when I got the Error 007, I checked my paper size.
        It says it is A4 size paper. But when I checked, it's actually smaller then Standard A4 size paper.
        I have replaced the paper with the correct size and wallah, the error message is gone.
        • rado_hristov
          May be fixing film is brouken . You have to replace fixing film or fixing film guide unit .
