CLC 3220 magenta fat lines
  • Esperanta
    • Oct 2008
    • 60
    Dear experts,
    I have a CLC 3220 machine with 48k print/copy for now.
    I have a magenta color issue, when print / copy.
    I have magenta fat lines on the copy/print sheet; sometimes this fat line does not appear on the printed/copied sheets. These fat lines appear either if the print is full color or small percentage of color.
    Please any suggestions
  • slybot
    • Sep 2010
    • 165
    looking at your examples i would say you have either a faulty cyan dev unit or a faulty cyan drum (assuming it is a 4 drum machine) that is where i would start at this point in time
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Whats the meter on this unit. And what kind of service has been done in the last 6 months.
      Looks like drums for now.
      • Esperanta
        • Oct 2008
        • 60
        the last service was before 6 months.
        the misc show Y-DRM-LF 75, M-DRM-LF 110, C-DRM-LF 110, B-DRM-LF 115
        • SCREWTAPE
          East Coast Imaging
          • 3396
          What was done?
          • badboys
            • Oct 2010
            • 69
            You can start with cleaning the magenta drum unit & the magenta transfer roller inside ITB assy. If cleaning fails then replace it both.
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Not a big fan of those options.
              But he can try.
              • Esperanta
                • Oct 2008
                • 60
                this not work.
                any other tips guys
                • zoraldinho
                  teacher-guide-expert-guru
                  • Mar 2008
                  • 5018
                  Make force stop in the middle of yob,pull out the drums and check witch one is the problem.
                  • teckat
                    • 16083
                    Originally posted by Esperanta
                    this not work.
                    any other tips guys
                    BOTTOM LINE IS=REPLACE ALL DRUMS AT SAME TIME/
                    Look at your posted color document/ notice something ??
                    if u understand the Color Process u will know what I mean -
                    • Fer
                      • Nov 2009
                      • 267
                      Replace the M-drum or better replace YMC or even beter replace em all.
                      The problem is a bad or flat spot on the primary charging roller, the flat spot cannot properly charge the charge the drum, on that side toner is attracted and causing M background.
                      • teckat
                        • 16083
                        good point>>
                        those Primary charge rollers need to be inspected/ they pop out of place on ends/ plastic ends also break/
                        also when coated with toner , they do not function well
