Canon IR105+ showing "Finisher can not be used"
  • tinnyjay
    • Oct 2009
    • 663
    Hello!
    My IR105+ is just showing on monitor :"Finisher can not be used".
    There is no error code,copier is working,but finisher its not alive.
    No moving trays,not showing in Service Mode.
    Can you help me please?
    "Who loves the roses,must also bear thumbs"
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Finisher is in limited function mode.In additional function mode turn application to off.
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1257
      Originally posted by tinnyjay
      Hello!
      Take the finisher out of limited functions mode as zoraldinho said....if the finisher has problems you will get an error that will need diagnosis ......if the sorter just had a one time error or a customer interfered with tray movement or something .....the finisher should reset & be usable.
      • SCREWTAPE
        East Coast Imaging
        • 3396
        You can't turn it off. You must rectified the problem first.
        @ Tinny.
        How does your error history look. Error codes???
        Three things that could play role here.
        Switching Regulator- FH3-2631-040
        Fuse pcb- FG3-1826-000
        Finisher controller- FG3-1875-060
        Check your error history log..
        • tinnyjay
          • Oct 2009
          • 663
          @ Tinny.
          No error code SCREWTAPE about finisher.In error history just E-00020-000 and E-00020-010(Toner Motor was dirty)
          I just have cleared Errors as normally.
          I have just tested boards of finisher with a Multimeter and every cell of them looks to be ok.
          But...after turn the copier on,there is no led on,on the finisher boards.
          • SCREWTAPE
            East Coast Imaging
            • 3396
            The finisher accessory power supply PCB is faulty. Switching Regulator- FH3-2631-040
            • tinnyjay
              • Oct 2009
              • 663
              You think i must change this?
              Please can you tell me K3N/4N finisher with which one FINISHER has a Switching Regulator compatible?
              • SCREWTAPE
                East Coast Imaging
                • 3396
                I'm afraid that's the only one.
                The only models I know are K1/K2/K3
                Did you check the plug.
                • nick55
                  • Jun 2010
                  • 51
                  my experience reminds me that if finisher is connected and its says "finisher cannot be used" I usually checked the connection and communication between copier and finisher. To quickly determine if the two are communicating is to have the finisher do the stapling and if it doesn't allow you to do that, then u have a communication problem bet. copier and finisher. the easiest solution i found is to check all the plugs especially the communication cable from finisher to copier. open the connector and check the connection. keep us posted for more hint
                  • tinnyjay
                    • Oct 2009
                    • 663
                    Screwtape is right.Seems to be a problem with a RL which is here :
                    JW1FSN-DC24V Panasonic Electric Works General Purpose / Industrial Relays
                    This RL when i plug in finisher wire,makes a rumor like "crack" and nothing else happens.
                    No leds on,on finisher DC Controller,no fan on,nothing on.
                    • Van Steal
                      • 177
                      As blazebusiness and zoraldindo said turn limited funtions off if there is a fault it will turn up again next time you used stapler etc. then work out fault.
                      • SCREWTAPE
                        East Coast Imaging
                        • 3396
                        Originally posted by Van Steal
                        As blaze business and zoraldindo said turn limited functions off if there is a fault it will turn up again next time you used stapler etc. then work out fault.
                        These machines don't work that way. There is no switch for functions limited mode.
                        The problem must be rectified.
                        • Van Steal
                          • 177
                          Ah sorry, used to working on clc's
                          • SCREWTAPE
                            East Coast Imaging
                            • 3396
                            No need to apologize We all learn something new everyday.
                            • tinnyjay
                              • Oct 2009
                              • 663
                              Screwtape please tell me something.
                              How is possible finisher dont work and there is not any error code showed on the screen?
                              Just to learn something more.
