Canon iR 2200 - ScanGear installed, Test works, but no Scanner installed
  • HughOD
    • Oct 2010
    • 17
    I must be missing something.
    We have an imageRunner 2200. I have the ScanGear Tool v2.2.1 installed. I have detected the printer / scanner properly (10.10.15.250). I select it, and test. All is good.
    If I go to any scanning software (Adobe Acrobat, Word, MS Fax & Scan, etc)... there is no twain device available for scanning.
    Doesn't the Window OS have to detect a scanner? I have tried this on Server 2003 and Windows 7... and can't seem to get the OS to know there is a scanner is there.
    Any help would be GREATLY appreciated!
    Thank you,
    Hugh
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Did you put the machine online?
    On the imageRUNNER, press the Scan button. Press Online.
    • HughOD
      • Oct 2010
      • 17
      Yes... but still no scanner device able to be selected on either Win 7 or Server 2003.
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Typically, when a driver installation appears to finish successfully but doesn't actually install, the problem can be traced to users' rights.
        • HughOD
          • Oct 2010
          • 17
          I'm there server admin on both machines. So I don't see it being user rights. I'm just plain perplexed.
          • SCREWTAPE
            East Coast Imaging
            • 3396
            From MS you go 'From Scanner or Camera' select network scan gear. If that option is missing then its a microsoft issue.
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Are you using these steps below.
              1. Launch Microsoft Word.
              2. Select Insert -> Picture -> From Scanner or Camera.
              3. On this screen, make sure that the Network ScanGear is selected.
              4. The next step is to select Custom Insert.
              *** It is important NOT to select the Insert button as this will result in a blank scanned page.
              5. At this point the Network ScanGear Tool will open and you can proceed with the scan.
              • SCREWTAPE
                East Coast Imaging
                • 3396
                Check out this article.
                How to insert scanned images in Office 2007 and Office 2003 Programs
                • HughOD
                  • Oct 2010
                  • 17
                  There are no scanners showing up on either machine. On Server 2003: If I go to Control Panel, Scanners and Cameras... no device is listed there. On Windows 7, does not show up under Devices & Printers.
                  I have a hard time saying a Microsoft issue... as it happend on multiple machines and multiple OS's. The driver is not being installed by the Canon software, from what I can tell.
                  • SCREWTAPE
                    East Coast Imaging
                    • 3396
                    From the MS app do you see this.
                    • HughOD
                      • Oct 2010
                      • 17
                      Screwtape... I know you are trying to help... and I appreciate it... but you aren't reading what I am writing.
                      I understand how to scan a document with applications. The problem is that when I go to scan, there is no scanner listed.
                      • SCREWTAPE
                        East Coast Imaging
                        • 3396
                        [ATTACH=CONFIG]6886[/ATTACH]
                        Hey just making sure all the steps are covered.
                        Have you tried to reinstall the Network scan gear tool.
                        • HughOD
                          • Oct 2010
                          • 17
                          Yes... but no help. I have now tried this on 6 different machines. 3 XP SP3, 2 Win7, 1 Server 2003. None of them get the scanner as an installed device.
                          • SCREWTAPE
                            East Coast Imaging
                            • 3396
                            Where did you download this driver from?
                            • HughOD
                              • Oct 2010
                              • 17
                              Canon U.S.A. : Support & Drivers : imageRUNNER 2200
