how do you set-up the ip address for network printing using the ufr driver? any help/tech assist is appreciated
irc 5185i
Tags: 5185, address, assist, c5180i, clr, connections, driver, error message, imagepass, inboxes, irc, lef, network, network printing, occur, print kit, printer driver, printing, scan settings, sdl, set, system settings, tcp/ip, tech, touch panel, user data, work
1. Press [Additional Functions].
2. On the touch panel display, press [System Settings].
3. Press [Network Settings].
4. Press [TCP/IP Settings].
5. Press [IP Address Settings]. Some newer devices will show IPv4 or IPv6 settings. Choose IPv4 Settings.
6. Make sure that IP Address is highlighted. Then press the [Clear] button to erase the current IP address and enter the new IP address using the keypad. Change the subnet mask and gateway settings in the same manner (as necessary).
* Since you are manually specifying a static IP Address, be sure that DHCP, BOOTP, and RARP are disabled.
7. Confirm the settings you specified, and then press [OK]. The display returns to the TCP/IP Settings screen.
8. Press [Done]. Repeat this step until the Additional Functions screen closes.
9. Reboot the machine via the proper procedure for your specific model.
10. Then install the driver on to the PC or network. -
this set-up, i know this one. i think u could do it this way if your bootrom is an "N". but if you have a "C" bootroom and have a ufr device configuration on ur unit, this ip address setting in the "system Management" set up is gray-out. I dont know if theres some option setting that i still dont know so could set up your ip address w/out going thru the "system management" set-up.Comment
in service mode
COPIER>OPTION>INT-FACE
IMG-CONT - set it to "3"
then reboot printer
do set up from Printer Tab n control panel
note** password prompt in setup is Fiery.1
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
The 'i' models only support the UFRII/PCL Printer Kit-N1 (which comes standard)
Don't you have to convert this machine. It requires a Open Interface Board in order to attach a fiery.
Do you have a i model or is there a box attach on the back of the machine.Comment
iR5185i can be configured to accept and function with an imagePASS. You have to order and install the Open Interface PCB or (R0-B PCB) into the machine. Once installed it will automatically disable the UFRII / PCL Print Kit-H1.The Canon part number to order the Open Interface Board is FM2-7430-000.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Maybe he just needs to change the option "display network messages" to on, than the ip adress option becomes selectable en an ip can be set.
1. System Settings
2. Network Settings
3. "display network messages" to on. its the only one not grayed out.Comment
this an "i" teckat...Thanks for sharingComment
QUOTE=Fer;175746]Maybe he just needs to change the option "display network messages" to on, than the ip adress option becomes selectable en an ip can be set.
1. System Settings
2. Network Settings
3. "display network messages" to on. its the only one not grayed out.[/QUOTE]
I'll go over again and try your suggestion....Many thanks FerComment
iR5185i can be configured to accept and function with an imagePASS. You have to order and install the Open Interface PCB or (R0-B PCB) into the machine. Once installed it will automatically disable the UFRII / PCL Print Kit-H1.The Canon part number to order the Open Interface Board is FM2-7430-000.Comment
10. Then install the driver on to the PC or network.Comment
Copier Models:
imageRUNNER C4080i / C4580i / C5180i
Supported Print Controllers:
- UFRII/PCL Printer Kit -N1 (standard)
- PS Printer Kit -N1 * (optional)
- imagePASS H1 ** (optional)
- ColorPASS GX100 ** (optional)
** Requires the optional Open Interface Board on the 'i' models.
* PS Printer Kit-N1 requires that UFRII/PCL Printer Kit-N1 and iR 512MB Expansion RAM-C1 be previously installed.
In addition, when connected to the imagePASS/ColorPASS, you will not be able to use the internal Canon UFRII/PCL printer kit.
On the i models (C5180i / C4580i / C4080i), the printer kit is standard and cannot be transferred.
Copier Models:
imageRUNNER C4080 / C4580 / C5180
- UFRII/PCL Printer Kit -N1 (optional)
- imagePASS H1 (optional)
- ColorPASS GX100 (optional)**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
All imageRUNNER-iR Series, All Color Enabled imageRUNNER Models, All imagePRESS Series The 'Change Settings / Display Connection Confirm' Option Under Network Settings
Change Settings/Display Connection Confirm' option is under
Additional Functions > System Settings > Network Settings'
This option can be set to [On] or [Off]:
[On] - If errors related to network connections occur, an error message is displayed on the touch panel display of the machine. If you want to use the machine in a network environment, select [On].
[Off] - Messages related to network connections are no longer displayed. If you want to use the machine without connecting to a network, select [Off].
* Even if you switch the [Change Settings/Display Connection Confirm] setting from 'On' to 'Off', if the network connections are correctly set they will not be disconnected. The settings in the Network Settings screen will not be changed.
* If the [Change Settings/Display Connection Confirm] option is set to [Off], then all of the other options under Network Settings will be grayed out and un-selectable. Canon USA, Inc. Systems & Technical Support Division**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
