Paper select problem ir 4570
  • sundeep202
    • Oct 2010
    • 26
    whenever i on my machine from standby mode it always ask to select paper. i have already selected all paper types which i have put in trays. can u plz help?
  • vj200729
    print mate
    • 81
    i cant fully understand your point .you can set any one tray or otherwise auto option by setting standered copy function in copier setting in additional function
    • SCREWTAPE
      East Coast Imaging
      • 3396
      The only time the machine will indicate this out of stand by is when there is paper in the bypass.
      How many trays do you have?
      Do you print to this machine?
      When you put paper on the glass what does it say. If its ltr size paper it should say LTR when that sheet is on the glass. If it says something other than that paper size then your original. Detection sensor or off.
      • sundeep202
        • Oct 2010
        • 26
        it doesnt sense the paper when i put on glass untill i switch it on by on/off button. i have selected tray 1(A4) for copy. tray second(A4) for print.
        • sundeep202
          • Oct 2010
          • 26
          i have already selected tray 1 (A4) for copy as default tray but still it asks. not every time but about 70% time ask for
          • teckat
            • 16083
            In Level 2
            COPIER > OPTION > BODY
            SCANSLCT >Turning ON or OFF the function of calculating a scan area from the selected paper size
            Copy Glass - <Setting range>
            0: OFF (Determining the scan area by document detection)
            1: ON (Determining the scan area by paper size)
            Level 2
            SENS-CNF Setting the arrangement of document detection sensors
            <Setting range>
            0: AB type [Default]
            1: Inch type
            2: A type
            Level 2
            COPIER > OPTION >USER
            SIZE-DET Turning the document size detection function ON or OFF
            <Setting range>
            0: OFF (When the platen is opened, the user will not be dazzled
            because the lamp does not light.)
            1: ON [Default]
            Common Settings
            enable/disable auto cassette
            select
            copy/printer/Box, other (manual feed: ON/*OFF + cassette: *ON/
            OFF; manual feed not applicable to printer)
            consider copy/paper type: ON/*OFF (toggle)
            make sure your cassette paper size selection dial is holding in place
            also check>
            SW4 is used to detect the state of the AB/Inch-configuration switch.
            The machine will assume the absence of a cassette if it detects a combination
            not found in the table. At this time, it does not move up the cassette lifter.
            Since the paper size is not identified, there will be no indication of a paper size
            on the control panel; when the cassette in question is selected, the machine will
            indicate a message prompting the supply of paper.
            If an envelope size is detected, an envelope cassette must be fitted.
            • SCREWTAPE
              East Coast Imaging
              • 3396
              I've seen that SW4 act up once in a while.
