canon fax jx210p error chk printing 5100
  • tariq65
    • Jun 2010
    • 84
    i gat a error canon fax jx210p error chk printing 5100 ani body help me thank you.
  • teckat
    • 16092
    think >5100 is a carriage error
    check for obstructions/ check obstructing the gears
    check/clean plastic encoder strip.
    Check the parallel port connector
    Try this>>>>>>>>
    1. Turn off printer
    2. Hold down Resume button and press Power button.
    3. Keep holding down Power button and let Resume button go.
    4. Press Resume button 2 times then let BOTH buttons go.
    5. Green lights will flash and then stop blinking.
    6. When green lights are solid, press the Resume button 4 times.
    7. Press the Power button and the printer should turn off, if not,
    press the Power button once more.
    8. Your printer should respond as normal..
