Don't have intravia for this model......is this a fan? and if so, which one?
Irc5180 e804-0000
E804 Controller fan error-
0000- Stop of the power fan was detected.
Check the connection of the power fan.
Replace the power fan.
0004 -Stop of the controller fan was detected.
Check the connection of the controller fan.
Replace the controller fan.
E804-0000: Power supply exhaust fan 1 (FM1) is faulty
Since the power supply exhaust fan 1 (FM1) did not rotate upon power-on and the error code "E804-0000" was displayed, the power supply exhaust fan 1=was replaced with a new one for solution.
- E804-0000 can be displayed when the shutdown of the power supply exhaust fan 1 is detected.
Field Remedy
1. With the main power switch turned ON, check to see if the power supply exhaust fan 1 (FM1) rotates.
2. If the power supply exhaust fan 1 does not rotate, re-fit J627 connector of the connector board and the connector of the power supply exhaust fan 1 (FM1).
3. If the symptom still occurs, replace the power supply exhaust fan (FM1) with a new one.
FK2-0360 Fan
COPIER>FUNCTION>PART-CHK
FAN= Specify fan checking the operation.
Setting range: 1 to 10 (7 or above are reserves)
Operation method
1)Select the item.
2)Enter the fan code with the numeric keypad.
1: Power supply exhaust fan 1 (FM1), Power supply exhaust fan 2 (FM10)
2: Fixing exhaust fan (FM2)
3: Machine exhaust fan (FM3)
4: Cleaner fan (FM4)
5: Delivery cooling fan (FM5)
6: Manual feed cooling fan (FM6)
7: Delivery vertical path cooling fan (FM8)
8: ITB cooling power supply fan (FM11)
9: Vertical path delivery exhaust fan (FM13)
10: Face-down tray cooling fan (FM12)
3)Press [OK].
4)Check the operation by pressing [FAN-ON].Last edited by teckat; 11-03-2010, 04:59 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Fan 2 was bad, they sure don't make it easy to get to it!Last edited by repeatcopiers; 11-09-2010, 02:13 AM.Comment
