IR3300i / Error 000014-0000
  • dbmoylan@gmail.com
    replied
    How would you get past the error message to enter the service function mode?
    I understand that that type error code may be cleared if the error code is cleared in service mode.
    Thanks.
  • Brian8506
    replied
    If I'm not mistaken, E014 will clear by power off/on if problem is corrected. If it was a power failure you may have taken out the fixing feeder drive or worse yet the power supply. However if you want to try clear procedure it addl functions/2 and 8 at same time/addl functions/copier/function/clear/err/ok/power off and on
    replied
    Thanks Simons . . . can you please confirm how to clear the code. Unit will not go past initial boot sequence and locks at the error code. Shutting downt the copier will not cause error code to go away. Will also check external power voltage & fuser.
  • Simons
    replied
    these usually dont e014. Check outlet power , clear the code and confirm the fuser is good .....
    replied
    Thanks Teckat - you are the most knowledgeable forum member out there!
    Am worried that when the power went out in the area that a power spike / brown out may have gotten past the power protection device & damaged the unit. When power was restored unit registered the E14-0000 error. Unit working before that power failure.
    replied
    Originally posted by dbmoylan@gmail.com
    Appreciate if anyone knows the error code 000014-0000 & how to recover from it for a Canon IR3300i copier. Thanks.
    IR3300i
    E014-0000
    1. Check the fixing unit for binds
    -There may be a bind in the fixing unit that impedes the movement of the fixing motor.
    2. Check the fixing motor connector
    -Is the connector of the fixing motor connected?
    -NO: Connect the connector.
    3. Check the Main power supply PCB (also known as the Switching Regulator)
    -Is the drive voltage (24VDC) of the fixing motor supplied by the main power supply PCB present?
    -The Main power supply PCB (also known as the Switching Regulator) can be checked by checking for 24VDC on J202-3 (24VU1-S) and J202-4 (OVU1).
    -NO 24VDC: Replace the main power supply PCB.
    4. Check the Fixing motor (M4) and DC controller PCB
    -Press the Start key. Is the lock signal of the fixing motor present at the connector (J312) on the DC controller PCB?
    -Lock signal: J312-B4 (FSRM_LOCK*) Does the signal from the DC controller PCB change from 0 to about 5 V when the Start key is pressed?
    -YES: Replace the fixing motor.
    -NO: Replace the DC controller PCB.
    replied
    Thanks - will do.
  • Brian8506
    replied
    I would pull the fuser and check to see if it turns smoothly. Otherwise the drive motor on the front side may be bad. Are you a tech? If not, you need one.
    replied
    Brian, thank you for your reply. Might you know where that might be (toner drum area?)? Might that be a fixing motor drive signal problem between that & clock?
  • Brian8506
    replied
    Check fuser for binding. Code is fuser drive problem.
    started a topic IR3300i / Error 000014-0000
