Canon 5185c - weird characters
  • Dexor
    • 223
    The machine occasionally begins to print hundreds of copies with either one character or one line of weird characters. It sometimes happens when the client sends a print job, but often it's just after idle time of few hours - it begins to happen. Wrong format? Is there something in the hd that needs to be taken out?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Usually is wrong driver.
    • Fer
      • Nov 2009
      • 267
      interference on the network cable?
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Can you post an image?
        • costd
          • Jan 2008
          • 409
          I agree - wrong or corupted driver. Can also happen when they send a print job of a document that uses a character set that is not supported by the printer but that was more common years ago with printer only units.
          • Canuck
            Tech Specialist
            • 1713
            I agree....un-install the drivers and install newest ones.Are they using PostScript,PCL or UFRII?
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              I deal with weird characters every day...except they're not printed on paper!
              • mrfixit51
                Lead Service Technician
                • 1975
                It is going to be a driver issue, or, years ago there was a virus specifically targeted at printers, called "bugbear" if I recall correctly. It was a pc virus that captured printer and printed nonsense till the paper ran out or customer intervened.
