CANON ir6870ci E000540-8003
  • podgurc
    • Aug 2025
    Hello,
    I have trouble on copier IR6870 Ci with attached finisher R1.
    Occasionally error code E000540-8003 appears. When coper is restarted copier starts to work normaly. I already check finisher.
    Have anybody had similary problem?
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Your problem is the finisher. It has been found that the lower safety cover can go under the actuator for the tray 1 switch. If the safety cover is under the actuator a E540
    Right way Wrong way
    Did you check this?
    • podgurc
      I will check it today.
      • podgurc
        I can't see atached pictures, can you atached again.
        • teckat
          • 16083
          • SCREWTAPE
            East Coast Imaging
            • 3396
            Thanks Tec.
            • teckat
              • 16083
