The communication between main and sub processor is interrupted, problem with your dc controller. Did you part any connectors from the controller? reseat them all. I hope, that you did not clean the controller with a vaccume, this can result in building up static and destroy the chips on the pcb.
If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
