IR2020 collate
  • Blues Guy
    • Aug 2009
    • 216
    IR2020 collate
    I have a 1 unit of Canon iR2020 basic machine. Without finisher.
    Can I do collate on this machine where 1st drawer I set to A4 size and the 2nd drawer I set to A4R ?
    I have ON the collate in the user setting and tried to do the copying of 2 set document but it does not work. The machine will pick the 1st drawer paper A4 size only.
    Is there any setting or it needs a finisher to do the collate ?
  • roho
    • Mar 2009
    • 844
    Is there an offset key in the finishing selections?
    • Brian8506
      • 1665
      If its the same as other models, I'm not as familiar with the 2020, you should be able to set the machine to rotate collate either under finisher or in additional functions. You may have to store it in standard settings.
      • teckat
        • 16083
        Check the settings below/ they may be in factory default setting *as OFF
        Copy Settings
        Additional Functions
        AUTO COLLATE: OFF(*), COLLATE, STAPLE
        TWO-SIDED: OFF(*), 1 > 2-SIDED, 2 > 2-SIDED, 2 > 1-SIDED, BOOK > 2-SIDED
        FRAME ERASE: OFF(*), ORG. FRAME ERASE, BOOK FRAME ERASE, BINDING HOLE
        2-PAGE SEPARATION: OFF(*), ON
        PAPER SELECT: AUTO(*), DRAWER 1, DRAWER 2, DRAWER 3, DRAWER 4
        *: Factory default
        CHECK PRINTER SETTINGS ALSO>>>
        2-SIDED PRINTING OFF(*), ON
        COLLATE OFF(*), COLLATE, OFFSET+COLLATE, OFFSET+GROUP, STAPLE
